low idle when clutch depressed - '98 2.3 CL
Old Sep 25, 2007 | 04:18 PM
Jesse H's Avatar
Default low idle when clutch depressed - '98 2.3 CL
Sorry to post here, I figure the CL is a mechanical twin of the Accord. Just picked one up for my gf, has 91K miles and I'm not sure what to make of this.
Car stopped, engine running, trans in neutral and clutch engaged - fine
Once I depress the pedal and disengage thte clutch the RPM will drop and the engine will want to stall. It also makes a clunking noise.
If I put it in 1st gear and roll away, it'll do it, but make a clunking noise. Clunking noise doesn't exist if I rev the motor in neutral, clutch engaged.
Not sure if this is just a simple throw out bearing or a crank issue? Thanks.
Old Sep 25, 2007 | 04:23 PM
accord99power's Avatar
Default Re: low idle when clutch depressed - '98 2.3 CL (Jesse H)
take to tranny shop, normally the diagnosis for free. or will know if its the clutch or not.
Old Sep 26, 2007 | 10:15 PM
Bozok's Avatar
Default Re: low idle when clutch depressed - '98 2.3 CL (accord99power)
I would guess that since the engine shows low RPM and has a clunking noise when the clutch is disengaged, then the transmission is not the problem.
Maybe when you engage the clutch and the transmission is in neutral, it stabilizes your crankshaft, making the clunk go away, allowing the RPMs to reach where they should. When you put the car in 1st and try to drive, it is requiring the engine to work a lot more than when the transmission is just in neutral, so the clunk (and lower RPMs) come back.
I would guess something is wrong with your crankshaft, like you thought, but I'm really not sure.
tn97prelude
Transmission & Drivetrain
Apr 20, 2011 07:51 PM
victor.m
Apr 4, 2009 09:19 PM
Vadim_D
Jan 14, 2009 08:26 PM
el_112
16
Feb 29, 2004 10:37 PM
