My synchros are f-cked
Old Jun 18, 2002 | 08:25 AM
Nate B's Avatar
Default My synchros are f-cked
Anyone know of a good shop in Chicago that could do this repair for a decent cost?
Old Jun 18, 2002 | 12:01 PM
MPH's Avatar
MPH
New User
Default Re: My synchros are f-cked (KILLERB18)
So are mine. How many miles on your R?
Old Jun 18, 2002 | 12:07 PM
Honda F1's Avatar
Default Re: My synchros are f-cked (MPH)
Try changing your transmission fliud. It might help a bit.
Old Jun 18, 2002 | 12:11 PM
MPH's Avatar
MPH
New User
Default Re: My synchros are f-cked (HONDAF1)
Yes, might give that a try.
Old Jun 18, 2002 | 12:13 PM
Nate B's Avatar
I've got a little over 23k. Changed the tranny fluid at 15K, this all seemed to happen after I installed a DC short shifter. One person I was talking to said the shift fork might be bent and that could cause the problem, does this sound possible, or is the synchro wear normal due to hard driving for a long time?
Old Jun 18, 2002 | 12:18 PM
MrBite's Avatar
what are the symptoms? Check your clutch master cylinder, I'm going through this with my GS-R right now. Check the fluid, if it's really nasty and black, the rubber seal might be going bad. Also check the clutch pedal, where the cylinder goes through the firewall. If it's leaking fluid then it's time to replace, and will be a hell of a lot cheaper than new synchros
[edit] though this is an '01, so I doubt it
[Modified by MrBite, 4:19 PM 6/18/2002]
Old Jun 18, 2002 | 12:24 PM
Nate B's Avatar
Default Re: My synchros are f-cked (MrBite)
Basically when I shift at redline into 3rd and even somtimes 4th the gears grind. Clutch is completely activated. If I take my time and smoothley shift into gear at redline sometimes it wont grind but usually it does. Only 3rd and 4th no other gears...
Old Jun 18, 2002 | 12:27 PM
sgT's Avatar
sgT
Welcome to the world of short shifters.
Old Jun 18, 2002 | 12:28 PM
Nate B's Avatar
Default Re: My synchros are f-cked (sgT)
I'm almost at the point where I wanna put my stock one back in. I like the feel of the short throw, but not when it's grinding the hell out of my gears
Old Jun 18, 2002 | 12:41 PM
MPH's Avatar
MPH
New User
"Basically when I shift at redline into 3rd and even somtimes 4th the gears grind. Clutch is completely activated."
Mine grinds in 3rd at redline. 8000 shift is fine but 8500 it grinds a little.
18,000 miles of smooth shifting.
[Modified by MPH, 4:42 PM 6/18/2002]
Old Jun 18, 2002 | 12:46 PM
Nate B's Avatar
It's a real pain in the *** isn't it? Do you have a short throw or stock shifter. I don't think thats causing the problem but just curious...
Old Jun 18, 2002 | 12:51 PM
MPH's Avatar
MPH
New User
Stock shifter. It happened in the middle of eliminations at a event I was in. Good thing I backed out of the staging lanes for a red light loss to a 15 second car. It's sucks but now its time for an FD.
Old Jun 18, 2002 | 01:50 PM
Eyewitness's Avatar
<---------- hates short shifters unless installed properly and made by B&M
importknight
Dec 27, 2010 08:46 PM
BigAnteg
Sep 9, 2010 10:20 PM
94DB8
Feb 5, 2008 09:05 PM
jdmcivic1
Dec 22, 2007 05:24 PM
ej1-usdm
Dec 5, 2007 04:03 AM
