B16 Pistons in B18A
Old Jun 18, 2002 | 08:19 AM
EGHatchy's Avatar
Default B16 Pistons in B18A
will B16 pistons fit perfectly on the LS rods? and should I buy anything else for these used B16 pistons?
Old Jun 18, 2002 | 08:28 AM
22seccivic's Avatar
Default Re: B16 Pistons in B18A (EGHatchy)
yes, atleast they did on mine.
Old Jun 18, 2002 | 08:48 AM
EGHatchy's Avatar
Default Re: B16 Pistons in B18A (22seccivic)
are there any old parts that I SHOULD replace in the block?
Old Jun 18, 2002 | 09:30 AM
Turbo Laser's Avatar
While you can the engine open install new rings, seals, gaskets, and get the LS rods resized and shotpeened. Only should run a couple hundred or so.
Old Jun 20, 2002 | 12:44 PM
See Are X's Avatar
Default Re: B16 Pistons in B18A (NOCARLOSER)
what kind of power difference is there with B16 Pistons on a LS??
Old Jun 20, 2002 | 12:46 PM
Kamin's Avatar
Default Re: B16 Pistons in B18A (See Are X)
good question
your upping the compression to about 10.8:1 over the 9ish LS compression. so a little, but not alot.
Old Jun 20, 2002 | 01:01 PM
See Are X's Avatar
Default Re: B16 Pistons in B18A (KAMiN)
what about horsepower wisE?
Old Jun 20, 2002 | 03:01 PM
Kamin's Avatar
its hard to tell
every motor is diffrent
like i said, a noticable diffrence.
but its not gonna go run an 11.
Old Jun 24, 2002 | 08:34 AM
JG Luder's Avatar
each compression point raised is approx 8-12 hp on a honda. give or take a few hp for different mods.
a1320honda
Jan 14, 2009 06:30 AM
2004cobra
Dec 27, 2006 11:55 PM
hOndafienD 04
Apr 6, 2005 08:42 PM
91civicDXdude
Jul 16, 2003 02:20 PM
ls_vtec_b18a1
Oct 13, 2002 12:03 PM
