Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
CV Boot Replaceable?
Old Sep 25, 2007 | 03:19 PM
AccordEX1991's Avatar
Default CV Boot Replaceable?
Is this doable?
Any procedure available?
Thanks
Old Sep 25, 2007 | 03:50 PM
toyomatt84's Avatar
Sanji
Yes, it's replaceable. I would have a shop do it, because then you get a short term guarantee, possibly even a warranty.
Old Sep 25, 2007 | 05:21 PM
fventura03's Avatar
x2, have a shop do it, it's not something a beginner should tackle...
if you feel you can handle it, you can buy a new CV boot from honda, also new end clips (the clamps or whatever you call it) unless you can reuse your old. you'll have to pull the cv joint from the shaft and clean everything very well before putting new grease there...
Old Sep 26, 2007 | 03:01 AM
Default Re: (fventura03)
Ok, got the axle off. New CV boot is on the way.
Where does the shaft come out? Outboard or inboard side?
Thanks.
Old Sep 26, 2007 | 05:01 AM
Boilermaker1's Avatar
you have to take the whole spider apart to get the boot off. For the $80 or $90 bucks a new axle is at autozone, just go get a whole axle, its a much easier.
Old Sep 26, 2007 | 06:48 AM
skipbarber's Avatar
new axle - core charge = about as much as an OEM boot kit and a tub of axle grease.
Old Sep 26, 2007 | 08:06 AM
Default Re: (skipbarber)
Yeah, I was surprised how cheap reman CV axles are.
Advanced: $79.99
O-Reilly: $59.99
Do they last 90k miles? We'll find out. Original lasted 98k miles.
I'll just get a reman and figure out how to repair my original one just for kicks.
Thanks.
Old Sep 26, 2007 | 04:47 PM
s13_240sx_92's Avatar
Default Re: (AccordEX1991)
replacing the boots is easy. you can tear it apart and see how the tripod holds the bearings and how the bearing fit into the "cup" not sure what the real name is.
Its messy but in my experience OEM honda axles are stronger than that **** that autozone sells. Good if you launch your car
Just be sure that the bearings are sliding correctly into the cup. i know on my prelude they could go in two ways.
good luck.
Old Sep 26, 2007 | 04:59 PM
Default Re: (s13_240sx_92)
I called some shops and they only replace the whole axle. No CV boot replacement only.
I think the outboard CV boot can only be replaced from the inboard end.
It looks like the inboard CV joint can slide out of the socket but the boot keeps it from totally sliding out.
That means I have to remove the boot off the inboard CV then slide the new outboard boot.
There is also a rubber piece in the middle of the shaft that needs to be taken out.
I'll try it this weekend and update on my findings. I'll bring it to work and use the parts washer to wash off the grease.
From there I can see how the CV is attached to the shaft.
Thanks.
Old Sep 27, 2007 | 02:39 PM
This is actually a very simple fix. I'll save at least $80 from Advanced or $250 from Majestic.
The outboard CV just snaps out if you give it a quick whack just like how the inboard spline is attached to the transaxle.
CV is washed in the parts washer and ready for the grease and boot kit.
I'll shoot pics later.
Old Sep 27, 2007 | 04:20 PM
Outboard CV off the axle spline:
Outboard spline end:
Old Sep 29, 2007 | 11:06 AM
CV axle boot replaced and LCA bushing pressed in and ready to go in.
Boot replacement not really hard but messy due to the grease.
Wear a pair of latex gloves and be ready to get dirty.
Old Sep 29, 2007 | 03:37 PM
fventura03's Avatar
how did you get the little clamp back on there afterwards?
Old Sep 29, 2007 | 09:44 PM
skipbarber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s13_240sx_92 &raquo;</TD></TR><TR><TD CLASS="quote">replacing the boots is easy. you can tear it apart and see how the tripod holds the bearings and how the bearing fit into the "cup" not sure what the real name is.
good luck. </TD></TR></TABLE>
autozone, napa, advanced, car quest, whatever, are remanufactured OEM axles. they are just as strong as stock.
Old Sep 30, 2007 | 07:35 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skipbarber &raquo;</TD></TR><TR><TD CLASS="quote">
autozone, napa, advanced, car quest, whatever, are remanufactured OEM axles. they are just as strong as stock.</TD></TR></TABLE>
Uhh no.. when someone turns in a Chinese made axle as a core and they rebuild it, is it an OEM?
Rebuilders will also use other non OEM parts when rebuilding.
I do agree sometimes its easier just getting a rebuild and call it a day rather than messing with the boots and bearing. But replacing boots isn't hard either, a little messy a little time consuming.
Old Sep 30, 2007 | 09:34 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fventura03 &raquo;</TD></TR><TR><TD CLASS="quote">how did you get the little clamp back on there afterwards?</TD></TR></TABLE>
The boot kit came with new clamps, axle nut, axle clips and grease.
I just used this tool to crimp the boot clamp. It's made by channel lock.
Old Sep 30, 2007 | 10:07 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skipbarber &raquo;</TD></TR><TR><TD CLASS="quote">autozone, napa, advanced, car quest, whatever, are remanufactured OEM axles. they are just as strong as stock.</TD></TR></TABLE>
The factory CV axle even with a torn boot was still tight at 98k miles. I was surprised.
Fix it as soon as you can and do not wait until all the grease is dry and dirt gets in, it should be rebuildable.
Cleaned, repacked and new replacement boot, it's as good as new and still factory original.
I will not trade the original for core exchange with a reman CV from Advanced if it was just a torn boot.
Old Oct 1, 2007 | 10:27 AM
fventura03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AccordEX1991 &raquo;</TD></TR><TR><TD CLASS="quote">
Oh i see, thanks. i thought you might've used the old ones...
Old Oct 3, 2007 | 07:56 AM
skipbarber's Avatar
last i heard there are regulations that ensure that even aftermarket components must meet or exceed OEM standards. I personally, have no problem using aftermarket components on my car.
Old Oct 3, 2007 | 08:04 AM
dmorris05's Avatar
Arent those tile cutters?
Old Oct 3, 2007 | 10:56 AM
Default Re: (dmorris05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmorris05 &raquo;</TD></TR><TR><TD CLASS="quote">
Arent those tile cutters?</TD></TR></TABLE>
Nope, it is an end cutting plier or nipper. It won't cut through the thick banding clamp. I used it just to pinch the clamp locking tab.
Old Nov 4, 2007 | 01:37 PM
Eucalyptus lude's Avatar
if you dont mind me asking, where id you purchase the boot kit? thanks
Old Nov 4, 2007 | 07:43 PM
last i heard there are regulations that ensure that even aftermarket components must meet or exceed OEM standards. I personally, have no problem using aftermarket components on my car.</TD></TR></TABLE>
Change your point here eh? Go buy some Taiwan trash OEM body parts and compare them to OEM Honda parts.. then talk to me..
And if you bring up CAPA standards you know even less than you think. the aftermarket industry self regulations mean little to nothing.
You can buy some $20 brake pads from China from autozone for your car.. They meet OEM spes but, are they as good as OEM Honda? F*ck NO!
And if you want to get anecdotal, I have auto zone reman axles fail on more than one occasion in the time/wear, where OEM Axles had faired fine.
Old Nov 4, 2007 | 09:01 PM
horchata's Avatar
thumbs up for the lifetime auto zone axles.
Old Nov 5, 2007 | 08:55 AM
recaroem2's Avatar
dont foget to put the3 grease in or your fucked. royally
