Ok Search Sucks... Spec B's + Stock Compression + ???
Old Jun 18, 2002 | 08:16 AM
AssPenny's Avatar
Default Ok Search Sucks... Spec B's + Stock Compression + ???
Ok I got an FPR on the way, I'm not sure which device I'm going to use to tune it (VAFC, PowerFC, Hondata) but what I need to know is should I pick up a set of prelude injectors while i'm getting parts together?
Here is the setup:
Stock bottom end
Stock head gasket
Stock head
Toda Springs
Toda Spec B's
Toda Cam Gears
Honda JDM 4-1 + 2.5 carsound
AEM FPR
Thanks guys, I'm trying to get a list of things together that I need so I can pick them up here and there when I get money and what not.
Craig - Who is broke as a joke
[Modified by AssPenny, 12:18 PM 6/18/2002]
Old Jun 18, 2002 | 08:17 AM
Willard's Avatar
Default Re: Ok Search Sucks... Spec B's + Stock Compression + ??? (AssPenny)
440's + 80 psi rail pressure should suit your setup just fine...
Will
Old Jun 18, 2002 | 08:19 AM
AssPenny's Avatar
Default Re: Ok Search Sucks... Spec B's + Stock Compression + ??? (Willard)
See i don't know if you are joking or not, I have no clue when it comes to fuel crap.
Craig - Who thinks will is joking due to the
Old Jun 18, 2002 | 08:20 AM
Willard's Avatar
I am joking... 'ludes' will work fine for now.
but if you plan on some 'other' stuff later... might as well only buy one set of injectors... and use them now.
Old Jun 18, 2002 | 08:24 AM
sackdz's Avatar
Why don't you throw a thinner head gasket on that biatch? William is yanking your chain, stock rail will be fine, but with only an FPR and Prelude injectors, I don't think you'll have much more capacity to work with if you ever decide to get crazy with compression. But it should suffice for your planned setup.
Somebody else confirm this pls.
Old Jun 18, 2002 | 08:36 AM
Dave-ROR's Avatar
PowerFC, 440s (lets hitup a yard for an old T/E/L tuuuuuuuuuuuuuuurbo) and some luck
no need to remove the head for the install so no reason to install a different HG.
Old Jun 18, 2002 | 08:37 AM
sgT's Avatar
sgT
Default Re: Ok Search Sucks... Spec B's + Stock Compression + ??? (01_Yeller_ITR)
ONLY get the powerFC if you get the software to control it.
Old Jun 18, 2002 | 08:38 AM
Dave-ROR's Avatar
Default Re: Ok Search Sucks... Spec B's + Stock Compression + ??? (sgT)
We'd just hold a can of PBR in front of Yack's face until he finished tuning da the car.
Old Jun 18, 2002 | 08:45 AM
AssPenny's Avatar
I think Jack might have a power fc for sale that i've been looking at. If only he took layaway
Old Jun 18, 2002 | 10:17 AM
Incognito's Avatar
Stock injectors will do you fine.
I ran stock injectors all last year, and stock pump, and it was good for 12.9's.
Mill the head 20 thousandths, or run a thinner head gasket though. It helps.
It only cost $50 - $70 to have the head milled.
I ran a VAFC with a Skunk2 chipped ECU.
Wannabe JDM
Jan 19, 2007 11:18 PM
EGkid
Sep 28, 2004 07:24 PM
orca
14
Apr 23, 2004 05:13 PM
Toda Built
12
Jan 19, 2004 02:19 PM
highrpmek
Jun 24, 2003 09:38 AM
