MSD spark plug wires ?
Anyone here using them on there d series ? I gotta buy a set and I want one that fit properly. My Magnecor wires dont sit properly.
I also want to color match red with my MSD Wire on my cap.
Modified by Rob. at 5:04 PM 9/25/2007
I dont think you are going to like them any better than your magnecor wires. I thought I blew my motor with nitrous once because the msd wire popped off of the dist cap at WOT.
I've had accell, magnecor and msd wires in the past and all I use now is OEM Honda. NOTHING out there fits better and can keep up with the amount of times I pull my wires off of my motor. I get mad thinking about it. lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90sedan »</TD></TR><TR><TD CLASS="quote">OEM ftw. </TD></TR></TABLE>
Yeah Rob...and with your ride, why go any different?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Its me DUB »</TD></TR><TR><TD CLASS="quote">
Yeah Rob...and with your ride, why go any different?</TD></TR></TABLE>
haha.
haha.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BadWay »</TD></TR><TR><TD CLASS="quote">the only aftermarket wires i've found that actually fit correctly and work decent and come in red are the taylors. </TD></TR></TABLE>
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rob. »</TD></TR><TR><TD CLASS="quote">Like I said, I want to color match my spark plug wires red with the red MSD Wire.</TD></TR></TABLE>
You and I are in the same boat!! I also have the msd cap that comes with the wire for the external coil, and want the msd cables so that it can match the msd coil cable. In a diffrent forum I heard nothing but good things about them. But a lot of times whatever part that is oem that can hold the abuse and still works perfect will get better reviews than any after market product.
So my question is this, I want to improve the look of my engine bay and being that I will be using a msd cap, yes I know the factory ignition is more than enougth, but like I said is a matter of taste/looks.
Will the MSD wires work?
We should find out if NGK, has them in red, just in case.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boricuanology »</TD></TR><TR><TD CLASS="quote">
We should find out if NGK, has them in red, just in case.</TD></TR></TABLE>
I did. NGK only makes them in Blue for our cars !
thanks
i didn't like running them on my D16 crx. the wires kept popping out of the valve cover. i ended up buying MSD and had no probs for over 2yrs
thanks
</TD></TR></TABLE>i didn't like running them on my D16 crx. the wires kept popping out of the valve cover. i ended up buying MSD and had no probs for over 2yrs
2k.civic.si
28
Mar 6, 2005 10:41 PM
oem and ngk are ok too if u cant afford msd
