What parts would I need to prep a d15b for 300hp turbo setup?
Old Sep 25, 2007 | 10:42 AM
whole9's Avatar
Default What parts would I need to prep a d15b for 300hp turbo setup?
What would be the list of parts I would be looking at getting? For making around 300-350 horsepower with a d15b
Old Sep 25, 2007 | 10:43 AM
whole9's Avatar
Default Re: What parts would I need to prep a d15b for 300hp turbo setup? (whole9)
I am talking internal engine parts btw. Everything outside of the engine I will have covered.
Old Sep 25, 2007 | 10:45 AM
Crx dude's Avatar
Vitara
Old Sep 25, 2007 | 10:48 AM
whole9's Avatar
Default Re: What parts would I need to prep a d15b for 300hp turbo setup? (Crx dude)
word. =] I heard good things about vitara
Old Sep 25, 2007 | 11:00 AM
whole9's Avatar
so all I need is some vitara pistons? and I am good to go for like 300-350 horsepower? thats amazing =] it says the fitment is a little off for the d15b unlike other d16's. anyway I guess all I would need is these pistons, and some better head bolts.
Old Sep 25, 2007 | 11:14 AM
garageEF's Avatar
you'll need to upgrade your rods also.
Old Sep 25, 2007 | 11:36 AM
whole9's Avatar
Default Re: What parts would I need to prep a d15b for 300hp turbo setup? (garageEF)
ok cool thx
Old Sep 25, 2007 | 11:54 AM
dxtosirex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garageEF &raquo;</TD></TR><TR><TD CLASS="quote">you'll need to upgrade your rods also.</TD></TR></TABLE>
good luck even finding rods for a D15. i look for around a year for my setup at the time. no luck.
Old Sep 25, 2007 | 12:20 PM
nuckingfuts's Avatar
Default Re: What parts would I need to prep a d15b for 300hp turbo setup? (dxtosirex)
how long do you want to make 300hp for?
wideband, good tune
vitara, eagle h beam, upgrade your clutch
Old Sep 25, 2007 | 12:31 PM
Crx dude's Avatar
Default Re: What parts would I need to prep a d15b for 300hp turbo setup? (nuckingfuts)
I think crower makes rods for the d15 but im not sure thou.
Old Sep 25, 2007 | 02:33 PM
julioboostamante's Avatar
why a d15? why not a d16? easier to find and rods are more readily available.
Old Sep 25, 2007 | 04:31 PM
dabigshmo's Avatar
Default Re: What parts would I need to prep a d15b for 300hp turbo setup? (julioboostamante)
yea i want to make 300hp outta my d15b on a turbo set up too.....wanna no what im doin? gettin a d16z6 hahaha as much as i hate to say it there are practically NO PARTS for the internals of a d15 but if you have any luck findin the stuff u need lemme no ud save me a ton of money
Old Sep 25, 2007 | 04:41 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: What parts would I need to prep a d15b for 300hp turbo setup? (dabigshmo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dabigshmo &raquo;</TD></TR><TR><TD CLASS="quote">yea i want to make 300hp outta my d15b on a turbo set up too.....wanna no what im doin? gettin a d16z6 hahaha as much as i hate to say it there are practically NO PARTS for the internals of a d15 but if you have any luck findin the stuff u need lemme no ud save me a ton of money</TD></TR></TABLE> wtf Ambler?
I grew up there
I lived in Butler park Condos as a youngin.
pm me I'm still semi local.
Old Sep 25, 2007 | 06:32 PM
whole9's Avatar
expletive that sucks, at least I can get the pistons for sure, someone, somebody, somewhere has to make rods and stuff for our engines!
Old Sep 25, 2007 | 06:57 PM
nihad's Avatar
d16a6 best motor out there to turbo get one at your local junk yard and rebuild it with some pistons and rods i guess they can hold like 300 hp stock blocks keep that in mind. a rebuild should cost like 300-400 stock parts
Old Sep 25, 2007 | 11:45 PM
whole9's Avatar
Default Re: (nihad)
Alright thanks, I might just end up trying to NA with the d15b for a while.
Old Sep 29, 2007 | 09:54 PM
JaredKaragen's Avatar
Default Re: (whole9)
posts, vitaras, and forged rods are al you would need to be able to safely hit that goal, a stage II cam would make it easier depending on how small of a turbo you go with.
Old Sep 29, 2007 | 11:58 PM
confucioussae's Avatar
head studs, injectors, fuel pump, MAP sensor, pistons, rods, rings, bearings, clutch...
Old Sep 30, 2007 | 06:41 PM
nihad's Avatar
d15b are just good replacement motors when the old d16 goes bad ha
Old Oct 4, 2007 | 10:44 AM
305miayellowteg's Avatar
sell your d15 buy a b18c (gsr) get a t3/t4 hybrib turbo out of evo8 aem fuel rail walbro 255 fuel pump bosh 550cc injectors an a hondatta 2000 with good tuning. this is my setup for my integra. im doing 280hp @9psi dd. on stock motor
Old Nov 2, 2007 | 05:03 PM
JDM_SOHC's Avatar
Default Re: What parts would I need to prep a d15b for 300hp turbo setup? (confucioussae)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by confucioussae &raquo;</TD></TR><TR><TD CLASS="quote">head studs, injectors, fuel pump, MAP sensor, pistons, rods, rings, bearings, clutch...</TD></TR></TABLE>
he said 300hp not pushing 450hp haha... But good list though, im almost all the way through it...
Old Nov 2, 2007 | 07:15 PM
blitz23's Avatar
JDM 1G-GTE supra pistons...
Old Nov 2, 2007 | 09:16 PM
da_dude's Avatar
The jdm D15B shared the same rods as the d16z6.
Old Feb 6, 2008 | 10:14 AM
jdmjunkie8's Avatar
Im about to do somewhat the same thing except im goin for 350, what turbine are you using?
Old Feb 6, 2008 | 10:45 AM
JDM_SOHC's Avatar
Default Re: What parts would I need to prep a d15b for 300hp turbo setup? (jdmjunkie8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjunkie8 &raquo;</TD></TR><TR><TD CLASS="quote">Im about to do somewhat the same thing except im goin for 350, what turbine are you using?</TD></TR></TABLE>
im at 218hp, on a t3t4 50 trim.. injectors, clutch, fuel pump, and some other small addon's.. and im only on 10psi... once my bottom end is built an i get MAP sensor i see no problem hittin 350hp...
