>>> PLease Help ME!<<<
I need help and have no clue what to do!
So i was redoing my whole coolant system and i took off the aluminum part that bolts into the block. (The that the line/house goes on) When i did both bolts broke and where stuck in the block.
So i tried to use an E-Z out/pro-grip. Had no luck at all. I then tried to drill out the bolt, planning on re-threading/using a threaded insert. And of coarse no luck again.
so i let my brother try while i run to the hardware store. When i got back he had tried drilling out the bolts. And on the one hole (top one) He drilled under the where the broken bolt is into the block and i have no clue why but he drilled one by the other hole too that's no where close to the original. SO is there any other ways to get that piece to stay on there??
I thought about jb weld? but idk if is strong enough
Please help me.
Please help me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p nut »</TD></TR><TR><TD CLASS="quote">Holy spam-a-thon. He's been posting this same thread in every forum. Doubt he has an ITR.
hmm does an itr tranny count?
</TD></TR></TABLE>hmm does an itr tranny count?
From: ...and then along comes the fcuking policia, PA
only if you broke the bolt off on the trans. sorry bout your mishap, broken bolts suck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by richardb53 »</TD></TR><TR><TD CLASS="quote">If it was my brother, I'd beat him severly about the head and shoulders!!!</TD></TR></TABLE>
x2 and its "the face, the breast, chest, neck and head"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soon2bH2b »</TD></TR><TR><TD CLASS="quote">
hmm does an itr tranny count?</TD></TR></TABLE>
Nope.
Nope.
Here's my post from a week or to ago
https://honda-tech.com/zerothread?id=2096210
Damn, that sucks. Depending on how deep and where your brother drilled that hole (
), you might be able to save the block by getting the shanks machined out, or try using a better bit yourself.
If you absolutely have to move your car, you can try JB weld, just let us know if it works, 'cause I don't.
No matter what you do, never let your brother touch your car again.
), you might be able to save the block by getting the shanks machined out, or try using a better bit yourself.If you absolutely have to move your car, you can try JB weld, just let us know if it works, 'cause I don't.
Soon2bH2b
Sep 25, 2007 08:29 AM
