'94 Prelude Timing Belt Change Info
Old Sep 25, 2007 | 01:40 AM
dr_g's Avatar
Default '94 Prelude Timing Belt Change Info
Hello !
I am contemplating changing the timing belts on my '94 Prelude. Are there any tips people can give me? Is the crankshaft nut a sod to untighten? Can you lock the engine by putting in gear (rather than using the special 50mm open socket thing?
Any advice appreciated!
Cheers,
Garth.
Old Sep 25, 2007 | 02:05 AM
CHK4TIX's Avatar
Default Re: '94 Prelude Timing Belt Change Info (dr_g)
If you are leaving the engine in the car and you have the someone to help. You can put the car in gear and have your friend put on the breaks and hold it until you loosen the bolt.
Old Sep 25, 2007 | 08:07 AM
esedulerp5tenin's Avatar
Default Re: '94 Prelude Timing Belt Change Info (CHK4TIX)
honestly, i tried every trick in the book to keep engine from moving when doing my t-belt (including someone else standing on the brakes with the car in gear) and after 2 weeks of failure, i finally broke down and bought the crank pulley holder tool. came off in 5 minutes
Old Sep 25, 2007 | 11:09 AM
jacoop86's Avatar
Default Re: '94 Prelude Timing Belt Change Info (esedulerp5tenin)
the easiest way to remove the crank pulley bolt is with a good impact, if you know someone with one that is... if you feel cheap, see if a local shop would loosen it for you??? 2nd easiest way is with the 50mm tool, but that didnt always work for me.
Old Sep 26, 2007 | 11:14 PM
dr_g's Avatar
Thanks Guys - I will try holdiong the brakes followed by an impact tool.
Garth.
Old Sep 27, 2007 | 11:52 AM
dr_g's Avatar
O.K., Stamping on the brakes didnt work, no way. I'm going to try an impact gun on Saturday.
By the way - is the crank bolt left hand thread??? Doesn't mention it in the manual unless 'special' bolt means left hand thread.
Cheers,
Garth.
Old Sep 28, 2007 | 04:27 AM
jacoop86's Avatar
Default Re: (dr_g)
[QUOTE=dr_g]
QUOTE]
At times it seems like it must be threaded the opposite way, but it isn't. Just stuck on like a bitch.
Old Sep 28, 2007 | 05:18 AM
tacticalcustoms's Avatar
Default Re: (jacoop86)
800 LBS of tq from my impact gun worked great
Old Sep 28, 2007 | 08:37 AM
jaywoodz's Avatar
Default Re: (tacticalcustoms)
yeah, do yourself a favor and check the crankshaft sensor and make sure it's in good working order. I'd hate to see someone put all that crap back together, then realize it's bad, yay!
Old Sep 29, 2007 | 05:21 AM
dr_g's Avatar
Default Re: (jaywoodz)
jaywoodz,
How do you check it?
Regards,
Garth.
Old Sep 29, 2007 | 05:42 AM
117's Avatar
117
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esedulerp5tenin &raquo;</TD></TR><TR><TD CLASS="quote">[i finally broke down and bought the crank pulley holder tool. came off in 5 minutes
I found this to be the best way to do it too. It keeps the crank from turning when you're removing/installing the crank pulley too. What I mean is that if you try to use the brakes, the crank moves a fair amount while you torque it. I don't like the crank turning against the bearings with all that torque being applied to the crank pulley bolt.
Old Oct 1, 2007 | 08:39 PM
snobordboy's Avatar
Moderator
Default Re: '94 Prelude Timing Belt Change Info (117)
Just borrow an impact gun, mine zinged right off no issues at all, yet I failed miserably trying to undo the one on my H23 without an impact.
Old Oct 4, 2007 | 01:14 PM
dr_g's Avatar
Guys,
Finally loosened the crank bolt tonight. Needed to make a crank pulley holding tool, and had an 18" Snap-On wreecking bar pushed by foot. After about 10 minutes shoving and kicking, the bolt loosened a bit. The forks on the joint of the Snap-On bar were flexing like mad, but it did the job in the end.
If we hadn't made the crank tool - not a prayer of loosening it.
Cheers,
Garth.
Old Oct 4, 2007 | 01:17 PM
vinuneuro's Avatar
Default Re: (dr_g)
I soaked the bolt in liquid wrench overnight. Next day, used the pulley holder tool and about 4ft of leverage. Came out in a few seconds.
Old Oct 6, 2007 | 01:19 AM
dr_g's Avatar
Guys,
I'm goint to change the belts this afternoon - is there a good procedure to adjust tension on the belts, or is it a case of releasing tension, removing the belts and then just letting the springs do their job?
Cheers,
Garth.
Old Oct 6, 2007 | 04:16 AM
vinuneuro's Avatar
Default Re: (dr_g)
If you have an H23, use this procedure since he converted to the manual tensioner. It's towards the end of the write-up:
https://honda-tech.com/zerothread/1857587
DOHCtec
Jul 1, 2019 04:35 PM
bretthuff0
Dec 29, 2010 12:28 PM
JDM_SOHC
27
Sep 28, 2009 09:05 AM
jimmy o.
Oct 9, 2008 12:16 PM
jwiedmayer
Jun 19, 2001 08:21 AM
