Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
eletrical?
Old Sep 25, 2007 | 01:31 AM
nahonda04's Avatar
Surje.motorsports
Default eletrical?
i have an 02' em2 and i replaced the battery and alternator, after i replaced the alternator my stereo has been fuctd up. if i put my drivers side window down the stereo gets louder. if the windows are up the stereo is low. if i drive fast the stereo gets super loud and when i stop it gets real low. i was on my way to jersey when it all happend, may dash blanked out and i couldnt see my speed or anything, i had no eletrical power for devices in my car, but car was still running and it wud buck in high rpm. it sucked ***. my car runs fine now but the stereo is still fuctd up. anyone got anyideas on whats going on? thnx in advance!!
Modified by nahonda04 at 6:17 PM 9/25/2007
Old Sep 25, 2007 | 03:23 AM
thinknology's Avatar
Default Re: eletrical? (nahonda04)
Your post was a little hard to read.... (suggest proofreading for better "understandability")
That sounds quite odd...
Do you have a factory stereo?
What type of voltage is your alternator putting out?
I'm assuming you got the right battery...?
What do you mean by....<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nahonda04 &raquo;</TD></TR><TR><TD CLASS="quote">... and it wud buck in high rpm.</TD></TR></TABLE>
Old Sep 25, 2007 | 04:53 AM
toyomatt84's Avatar
Sanji
It sounds as if there is a faulty ground in the electrical system somewhere. You may want to check the ground from your alternator to the chassis. If it looks corroded or broken, replace it. I would just replace it anyways, for sure sake of better starting power. You could also add a couple ground wires from the chassis to the engine, via the timing belt cover, and the valve cover.
Old Sep 25, 2007 | 05:17 PM
nahonda04's Avatar
Surje.motorsports
thanx
pornfreaktommie
May 31, 2013 08:01 AM
FRKWOO
14
Feb 14, 2010 09:54 AM
97itr86
22
Jul 31, 2007 10:35 AM
darkd1gt
Nov 22, 2005 07:42 PM
