ITS PULLS TO THE LEFT REAL BAD !!! HELP ME
Old Sep 24, 2007 | 08:55 PM
civicgsr116's Avatar
Default ITS PULLS TO THE LEFT REAL BAD !!! HELP ME
I JUST BROUGHT A 94 HONDA ACCORD BUT IT PULLS TO THE LEFT AND I DONT KNOW WAT IT IS ......WHEN I LET GO OF THE WHEEL IT JUMPS TO THE LEFT REAL FAST...WAT COULD IT BE?????
Old Sep 24, 2007 | 09:04 PM
02 accord's Avatar
Default Re: ITS PULLS TO THE LEFT REAL BAD !!! HELP ME (civicgsr116)
ALIGNMENT. Now you can stop yelling.
Old Sep 24, 2007 | 09:09 PM
Default Re: ITS PULLS TO THE LEFT REAL BAD !!! HELP ME (02 accord)
I dont think thats it b/c it pulls REAL fast and i pretty much have to have the wheel side ways
Old Sep 24, 2007 | 09:41 PM
shibbywhitedude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 accord &raquo;</TD></TR><TR><TD CLASS="quote">ALIGNMENT. Now you can stop yelling.</TD></TR></TABLE>
X2 It's more than likely your alignment. Not even an out of balance wheel would make your car pull that violently...
Old Sep 24, 2007 | 09:48 PM
Default Re: ITS PULLS TO THE LEFT REAL BAD !!! HELP ME (shibbywhitedude)
also it droped pretty much all the way(it was ike that when i got it) it rubs in the wheel well can that have something to do with it
Old Sep 24, 2007 | 09:53 PM
Well rubbing isn't hurting unless it's constantly rubbing while doing normal driving... I'm betting your caster and camber are both ridiculously off meaning raise it back up some and go get an alignment.
Old Sep 25, 2007 | 01:19 AM
Doostur's Avatar
Old Sep 25, 2007 | 10:32 AM
Crx dude's Avatar
are they cut springs? if so throw them in the trash and get proper ones that are safe. also get your alignment done.
Old Sep 25, 2007 | 10:41 AM
Default Re: ITS PULLS TO THE LEFT REAL BAD !!! HELP ME (Crx dude)
nah there not cut there coilovers they are just at its lowest it can be
Modified by civicgsr116 at 1:43 PM 9/25/2007
Old Sep 25, 2007 | 02:43 PM
DrZFiNeSt's Avatar
Just get an alignment and balance and problem should go away.
Old Sep 25, 2007 | 04:27 PM
accord99power's Avatar
alignment will make the car pull alittle but not that much, rotate your tires then let us know if you have same prob, your tire has a pull in it man.
Old Sep 25, 2007 | 05:35 PM
Crx dude's Avatar
Default Re: ITS PULLS TO THE LEFT REAL BAD !!! HELP ME (accord99power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord99power &raquo;</TD></TR><TR><TD CLASS="quote">alignment will make the car pull alittle but not that much, rotate your tires then let us know if you have same prob, your tire has a pull in it man. </TD></TR></TABLE>
depends on how far its out.
Old Sep 26, 2007 | 02:24 PM
Honda-Master's Avatar
i would swap the frt tires side to side first and test drive it again,,
If it still pulls left i am willing to bet you got some suspension issues ( bent or badly worn parts ) .. If it pulls rt you got bad tire ( s)
alignment out of specs is not going to make a car pull that fast ,, and if alignment IS indeed that far off than something is bent ..
Swap the tires and post the results
Old Sep 26, 2007 | 03:06 PM
Default Re: ITS PULLS TO THE LEFT REAL BAD !!! HELP ME (Honda-Master)
thankyou! exactly what i said.
Accord2009
Jul 19, 2017 07:56 AM
jjsifo
Dec 28, 2010 12:56 PM
MonkeyPuzzle
Dec 30, 2006 08:06 PM
nygunrunners
Nov 3, 2004 03:54 PM
theBird
Dec 12, 2003 04:43 PM
