Passenger axle keeps popong out of trany?
Old Sep 24, 2007 | 06:29 PM
psegs80's Avatar
Default Passenger axle keeps popong out of trany?
I have an EK with a Type r (b18c) motor and trany. I'm using a Kaaz 1.5Way LSD dif with ats gears. I have a set of stage 2 axles from CVTech. I used the axles before when I had the stock trany with no prob!!!
The axle pops out when accalerating hard generally at high RPM in 3rd gear!!!!
I got the axle remanufactered with a new end and C clamp. I installed it into the trany, I can pull hard on it by hand and pull it out...could it be the dif????
Old Sep 24, 2007 | 06:33 PM
Parada's Avatar
Default Re: Passenger axle keeps popong out of trany? (psegs80)
how much damage did this do when it popped out in 3rd at high rpm, my friend and i were cruisin through our neighbourhood last night at about 20 30km/h and his axle popped out, made an incredibly horrifying noise and he was almost crying, cant imagine what this did to your car.
Old Sep 24, 2007 | 06:48 PM
psegs80's Avatar
Default Re: Passenger axle keeps popong out of trany? (Parada)
Actually, only a little bit of metal shavings where worn off the end the one time it completely came out!!! The other times it would just pop out like 1/4 inch so trany fluid would leak out!
Old Sep 24, 2007 | 11:34 PM
ITR_cam's Avatar
has it got the 'C' clip on the end of the axle.. if it doesnt have this it will pop out no matter what
Old Sep 24, 2007 | 11:47 PM
floatfisher's Avatar
stop riding wit phat chicks and u will elliminate ur problems
Old Sep 25, 2007 | 03:24 AM
Dave_B's Avatar
It's a C-clip issue... Just ask Hooch'N about it from CMP.
Old Sep 25, 2007 | 05:25 AM
psegs80's Avatar
Default Re: (Dave_B)
Ya those phat chicks keep wanting rides lol
I do have a c clip on the axle, a new one to...Is it possible the dif wasn't shimed or pre-loaded properly and that's why the c clip isn't sitting in properly????
Old Sep 25, 2007 | 05:35 AM
Dave_B's Avatar
Default Re: (psegs80)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psegs80 &raquo;</TD></TR><TR><TD CLASS="quote">Ya those phat chicks keep wanting rides lol
I do have a c clip on the axle, a new one to...Is it possible the dif wasn't shimed or pre-loaded properly and that's why the c clip isn't sitting in properly????</TD></TR></TABLE>
I'm thinking it's the "remachining" process that messed it up!!! Try an Autozone rebuilt and seee if it holds in there, if so... you'll know the "machining" was the problem.
Old Sep 25, 2007 | 06:00 AM
psegs80's Avatar
I just spoke to cvtech, and they where under the impression I had a b16a trany but when I confirmed to them that I had a JDM type R trany, they told me that the end needs to be 1/8 longer like the h22a's!!!
So that would explain why the c clip isn't sitting in properly!!!
Old Sep 25, 2007 | 06:27 AM
Dave_B's Avatar
Bingo...
Old Sep 25, 2007 | 11:14 AM
Hooch'n's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">It's a C-clip issue... Just ask Hooch'N about it from CMP. </TD></TR></TABLE> Yep, C clip just get an OEM one and your good.....See sig for details
Old Sep 25, 2007 | 11:31 AM
Mugen Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">Try an Autozone rebuilt</TD></TR></TABLE>
Worst advice from Dave B evAr!
Old Sep 25, 2007 | 04:10 PM
Hooch'n's Avatar
I'm thinking it's the "remachining" process that messed it up!!! Try an Autozone rebuilt and seee if it holds in there, if so... you'll know the "machining" was the problem. </TD></TR></TABLE>
Pepboys axles are better.......since i have trashed 1 vs 2 Autozone Axles....really the best kind are OEM
Old Sep 25, 2007 | 04:25 PM
98 ITR's Avatar
Default Re: (Mugen Mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike &raquo;</TD></TR><TR><TD CLASS="quote">
Worst advice from Dave B evAr!</TD></TR></TABLE>
Meh ...
Rebuilt Axles for circuit use =
Rebuilt Axles for Drag strip = Holy mother of god
Old Oct 3, 2007 | 11:01 AM
psegs80's Avatar
Default Re: (98 ITR)
Ok so the 1/8 longer JDM type R inner still comes out. Call Kaaz and they told me to test my diff (one wheel of the ground and try to release the clutch slowly to see if the contact tire turns) and to make sure my axle seal is in enough!!!!!
Old Oct 3, 2007 | 11:23 AM
Mugen Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98 ITR &raquo;</TD></TR><TR><TD CLASS="quote">
Meh ...
You can purchase new axles from NAPA for a little more than a rebuilt at Vatozone, and the quality is much better. I've tried 3 different axles from Vatozone - first 2 were too loose, third was so tight that if I let go of the steering wheel it would snap to the left.
Old Oct 3, 2007 | 11:28 AM
JjuuN R's Avatar
Default Re: (floatfisher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by floatfisher &raquo;</TD></TR><TR><TD CLASS="quote">stop riding wit phat chicks and u will elliminate ur problems</TD></TR></TABLE>
If you'd keep a closer eye on your girl then he'd be alright.
Old Oct 3, 2007 | 11:31 AM
Dave_B's Avatar
Ok ok... so I don't use them either... trying to save the d00d some $$$
For me... I'd send out a good axle to Gator Axles.
I have set of their RR axles waiting to go into the PY, the OEM ones that come out will be sent to them for a rebuild.
Mike... is that better?
angrysmileyface
Oct 11, 2015 03:57 PM
jaerikd
Oct 8, 2009 05:07 PM
2wheelsmoker
Nov 6, 2006 01:25 PM
tyro
Jul 7, 2006 09:52 AM
david90
Jun 15, 2004 03:33 PM
