motor mount removal
hey guys i was wondering what is the easiest way to remove the upper drivers side motor mount without a engine hoist?? what steps do i need to take to do this?
im in college and currently dont have access to a hoist but need to get this problem fixed as soon as possible.
any help would be GREATLY appreciated!
Thanks!!
Thanks!!
Just put a floor jack under the motor on that side.. take the weight off the mount, and remove the bolt holding it into the bracket.. then remove the 2 bolts holding the mount onto the motor..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94delslo »</TD></TR><TR><TD CLASS="quote">ok cool. i wasnt sure if that would work or not. so what about the rear motor mount? i dont have to unbolt that to do it would i?</TD></TR></TABLE>
No you won't. You simply have to remove the strain on the motor mount you're removing long enough to replace it. Be sure to use a flat piece of wood under the oil pan so as not to damage it.
ConceptVBS
Honda Civic (2001 - 2005)
Apr 17, 2014 06:14 AM
