eg hatch w/gsr will not rev past 3k help
Old Sep 24, 2007 | 03:20 PM
Train 1's Avatar
Default eg hatch w/gsr will not rev past 3k help
hi i am new to this site and am looking for help
i have a 93 hatch with a gsr swap and itr trans
full built, rods, 12.5:1cr, and lots of head work , apex vafc, msd ex-coil
it starts and idles fine but if you give it gas more than 10% it starts to rev and cuts at 3k like no spark/rev limit was hit?
it is getting spark.
if i give it very little gas like less than 10% it will rev to 5k
there are no cel's
thank'x
Old Sep 24, 2007 | 03:25 PM
lsjon's Avatar
Default Re: eg hatch w/gsr will not rev past 3k help (Train 1)
99% of the time when you have this problem, its a problem with your ecu OR whatever standalone management your using. If your using a chipped ecu make sure the map is burned correctly.
Old Sep 24, 2007 | 03:33 PM
fatpride111's Avatar
my cousins dodge had this problem, but it was a clogged cat
Old Sep 24, 2007 | 04:11 PM
Train 1's Avatar
Default Re: eg hatch w/gsr will not rev past 3k help (lsjon)
the ecu is a p72 and i used it to run my turbo mini me 12+psi = bang! with never a problem the apex vafc is the only new add on
would an ignitor cause this?
brad22486
13
Feb 6, 2021 08:08 AM
mmmbarp
Dec 5, 2010 01:30 PM
pearlwhitecrx
Feb 14, 2003 07:39 AM
Hondasaurs
Nov 15, 2002 01:46 PM
