prep work for an h22
thinking about swapping an h22 into my 1995 civic 4 door i've heard new suspension is a good idea....ne suggestions or other stuff i may want to put on to make this a great swap...thanks
stiffer springs, better shocks, and a good set of BRAKES. other than that you could go for some sway bars etc. main thing is to just get some good springs/shocks cuz the engine is ~150lbs heavier than your stock one would be, and the engine sits lower to the ground..if you don't get some stiffer springs/shocks you'll be bottoming out a lot.
Racinghonda8
Sep 19, 2007 05:55 PM
drkblue_civic
Jul 7, 2002 03:19 PM
