Searched First; Timing Gear Removal
Old Sep 24, 2007 | 02:49 PM
BigPlansNoMoney's Avatar
Default Searched First; Timing Gear Removal
F22A from '91 Accord
How is it done? Is there a special kind of tool that Honda makes? I've tried three different gear pullers and none will even come close enough to get tight on the gear to get set to pull. Help.
Old Sep 24, 2007 | 05:43 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: Searched First; Timing Gear Removal (Justin_Bradley)
Theres a bolt that holds the pulley on. Remove the bolt and remove the pulley. If it wont come off you may have to remove the cam as the pulley was not meant to be pulled. It should just come off.
Old Sep 25, 2007 | 07:57 AM
standbackimapro's Avatar
Default Re: Searched First; Timing Gear Removal (cb7-R)
Are you talking about the Gear on the CAM... or the one on the Crank
Old Sep 25, 2007 | 12:53 PM
Eddiebx's Avatar
make sure the key is out first, if the woodruff key is still in theslot u will never get the gear out. sometimes they force the key in too and it gets stuck.
i had to cut the gear off on one of my customers cars once because the last person who installed it, put it in a bit cocked, so the key got forced in and stuck.
Sam1am26
Dec 30, 2019 09:50 AM
mem94043
Jan 16, 2012 10:47 AM
Svery
Feb 8, 2010 01:21 AM
david90
Sep 29, 2003 03:15 AM
