Dynoed my Si today at ProStreet!
I believe my car did pretty good!
Mods: Intake, Header, 2.5" piping, & Hondata Reflash
The lowest hp run was because the sensor at the exhuast tip fell off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tzang »</TD></TR><TR><TD CLASS="quote">
the wideband? that has nothing to do with your HP results.
anyway, what did you put down....i can't view pics at work.
</TD></TR></TABLE>the wideband? that has nothing to do with your HP results.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tzang »</TD></TR><TR><TD CLASS="quote">Oh ok nvm then..haha..the guy said my car was too hot too..lol..the best run was 199 hp 143 tq</TD></TR></TABLE>
thats good! just a while back B series guys would kill to hit numbers like that....now it's so easy
and yes HP starts to drop off once everything becomes heat soaked.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtySOHC’s »</TD></TR><TR><TD CLASS="quote">
HEAT BAD FOR ENGINES
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrainFart »</TD></TR><TR><TD CLASS="quote">Did you dyno the car stock to see if the money you put in was worth the power gains? </TD></TR></TABLE>
thats what i did...i got a baseline of my car.
but good runs...dont know how you would know if your car had any gains or what not..but im pretty sure you did. your a/f is weird too.
I didn't dyno my car stock..but I'm pretty impressed with my numbers....according to other's that have the same mods..they are getting 190s-197 hp...so if mines pulled 199 wooot i must be pretty lucky.
I thought the car would compensate for the mods and adjust the A/F ratio? I thought I read somewhere a car runs best at a 14:1 a/f ratio, so does that mean your car is under-performing compared to what it could do?
oh word?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Caveman74 »</TD></TR><TR><TD CLASS="quote">I did 199.8 with DCRH, Injen SR and STOCK exhaust</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elohel »</TD></TR><TR><TD CLASS="quote">I thought the car would compensate for the mods and adjust the A/F ratio? I thought I read somewhere a car runs best at a 14:1 a/f ratio, so does that mean your car is under-performing compared to what it could do?</TD></TR></TABLE>
you want to be in the 14's for normal driving.
under load you want to be as close to 13.0 as possible. 14 underload is super lean.
that is a generalization...it varies between setups
14:1 air fuel ratio is for emessions purposes only...but performance wise you might wanna consider a 12:5 -
12:7 air fuel ratio or atleast close to 13's
Modified by FG_2_KILLS at 8:40 PM 9/25/2007
12:7 air fuel ratio or atleast close to 13'sModified by FG_2_KILLS at 8:40 PM 9/25/2007
that is a generalization...it varies between setups</TD></TR></TABLE>
hahaha...same answer you got...
Different dyno, different day, different results
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tzang »</TD></TR><TR><TD CLASS="quote">DC race header, stock exhaust with custom 2.5" piping
What do you mean by "stock exhaust" with custom 2.5 pipping?
</TD></TR></TABLE>What do you mean by "stock exhaust" with custom 2.5 pipping?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tam N »</TD></TR><TR><TD CLASS="quote">
Different dyno, different day, different results</TD></TR></TABLE>
Blah. blah , blah.. just goes to prove that we are very close in numbers with almost the same setup. He also has the reflash
And I have seen plenty of dynoes that have expensive catback exhaust and header that you would think would hit WAY higher numbers and dont.
