oem rear sway setup help...
Old Sep 24, 2007 | 12:22 PM
bmoua's Avatar
Default oem rear sway setup help...
i'm picking up a oem em1 13mm rear sway setup and i wanted to know if the em1 mounting bracket works with the gsr 14mm rear sway bar? The brackets i'm talking about are the brackets which which hold the sway bar to the chassis(rear subframe). I checked the part numbers and the gsr and em1 brackets are different. I know the 94-99 integra LS/RS uses the same bracket as the gsr, so wouldn't the em1 rear sway bolt up?
here is a link to the gsr parts...part # 12 and 13
http://www.acuraoemparts.com/d...ch=no
link to em1 parts...part # 30
http://bkhondaparts.com/billka...dIrno=
Old Sep 24, 2007 | 03:40 PM
bmoua's Avatar
anybody?
Old Sep 24, 2007 | 03:50 PM
egsleepercivic's Avatar
you will need the 13mm bushing, the d brackets should work as long as the holes line up. the bracket should be fine as well, the only problem would be if the outer diameter of the bushing is to small or big for the si d brackets
hope this makes sense
gl
Old Sep 24, 2007 | 04:06 PM
bmoua's Avatar
Default Re: (egsleepercivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic &raquo;</TD></TR><TR><TD CLASS="quote">you will need the 13mm bushing, the d brackets should work as long as the holes line up. the bracket should be fine as well, the only problem would be if the outer diameter of the bushing is to small or big for the si d brackets
gl </TD></TR></TABLE>
well i have the gsr bushings and d brackets, my question is will the gsr d brackets bolt up to the em1 bracket stabilizer
Old Sep 24, 2007 | 06:07 PM
the gsr bushings are 14mm, and your using a 13mm bar. maybe I am misunderstanding you
Old Sep 25, 2007 | 10:19 AM
bmoua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic &raquo;</TD></TR><TR><TD CLASS="quote">the gsr bushings are 14mm, and your using a 13mm bar. maybe I am misunderstanding you </TD></TR></TABLE>
haha sorry bro, basically i'm using everything off of a gsr. what i need to know is if the gsr setup bolts up to the em1 bracket stabilizer (bracket which holds the sway bar to the chassis)
Old Sep 25, 2007 | 10:22 AM
kaiba's Avatar
Default Re: (bmoua)
Everthing works but you'll have to use the mounting bracket from 99-00 si
rickscrx
Dec 19, 2011 05:08 AM
JDM Like Whoa
Mar 6, 2011 03:32 PM
JDM Like Whoa
Suspension & Brakes
Sep 29, 2010 05:25 PM
abs0lutexer0
Apr 26, 2003 03:47 PM
