need help starting 98 prelude with 95 motor
Old Sep 24, 2007 | 11:21 AM
njracer's Avatar
Default need help starting 98 prelude with 95 motor
My friend blew his motor, so he bought a 95 motor. He used the 98 wiring and distributer. He also has the obd2 to obd1 conversion running a 95 ecu. We checked everything to fuses,relays, to ground wires and still no luck. The motor cranks hard but wont start. Any suggestions?
Old Sep 24, 2007 | 11:28 AM
117's Avatar
117
You used the 5Gen engine wiring harness, so did you swap the oil pumps over so the new engine would use the 5Gen TDC and CKP (IIRC) sensors? They're located on the oil pump on the 5Gen and in the distributor on the 4Gen.
Old Sep 24, 2007 | 12:48 PM
JDMhondalude22's Avatar
Default Re: (117)
after cranking for so long it should throw a code. find out what the code is. but most problems i would say resort to something with the distributor. if you can find out if its getting fuel or not, that would be helpful also. along with spark.
Old Sep 24, 2007 | 12:56 PM
njracer's Avatar
Default Re: (117)
Will the ckf bypass trick help.
Old Sep 24, 2007 | 01:56 PM
v4lu3s's Avatar
RTFM
there is no ckf on a prelude.
you need the oil pump and sensors off the old engine to put on the new one.
Old Sep 24, 2007 | 02:14 PM
vietdragontekx's Avatar
Default Re: (117)
you need to rewire the crank position sensor, because you using and obd1 ECU. there a write up somewhere on here how to rewire the crank position sensor to the distributor. either do that or change over the crank position sensor on the 5th gen over to the obd1 motor.
Old Sep 24, 2007 | 02:43 PM
96SinisteR_Lude's Avatar
Default Re: (117)
if you want ill trade you my 2001 h22a4 motor for ur 95 cuz i purchase it for a 96 but to much work for my uncle to put together so if you want to we can trade so you can drive ur car and so can i....hit up my email---Jerzmostwanted33@aol.com
Old Sep 24, 2007 | 02:59 PM
Default Re: (96SinisteR_Lude)
don't 96 prelue is pre obd2 and use the crank sensor like the obd2 5th gen?
Old Sep 30, 2007 | 02:51 AM
Default Re: (vietdragontekx)
nah im saying a purchase a 96 type-s motor cuz im new to prelude but the type-s only came from 97up didnt kno that so, since he has a 98 prelude and i have a 96 prelude ill trade him my 01 for his 95, unless he got his car going, cuz i got screwed when i bought this motor and since he's in new jersey i would be alot easier wit out doin shipping
Old Sep 30, 2007 | 10:50 AM
98vtec's Avatar
moderator emeritus
Default Re: (117)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 117 &raquo;</TD></TR><TR><TD CLASS="quote">You used the 5Gen engine wiring harness, so did you swap the oil pumps over so the new engine would use the 5Gen TDC and CKP (IIRC) sensors? They're located on the oil pump on the 5Gen and in the distributor on the 4Gen.</TD></TR></TABLE>
Old Sep 30, 2007 | 10:53 AM
Ralleh's Avatar
How much more expensive are 5th gen motors?
Old Sep 30, 2007 | 12:36 PM
Default Re: (Ralleh)
depends mine was 3000, but im selling it for 1200 just to get a reg. h22 motor so i can drive my car
IA95civicDX
Oct 24, 2011 02:19 PM
1998typesh
Jul 6, 2011 05:51 PM
ZCSp0ngeR
Feb 15, 2009 09:22 AM
djsire
Dec 10, 2006 01:20 PM
