Install an internal coil distributor on an accord that was using an external coil?
Old Sep 24, 2007 | 10:50 AM
Sprayteg's Avatar
Default Install an internal coil distributor on an accord that was using an external coil?
A customer leave me his honda accord 94 2.2l with a faulty distributor, he choose to buy one from from richporter technology since it cost less than my parts dealer.
His car has a TEC distributor but with an external coil, I know that you have two different brand of distributor for this model but didn't know that they have two TEC model too. So he order a TEC distributor but with an internal coil....
I don't have the wiring from the two models for now, can I just modify the wiring to use the new distributor or use the new distibutor with the old coil ?
If someone have the two wirings diagrams it would help me too.
Link to richporter : http://www.richporter.ca/oemproducts.html
92-95 2156cc with TEC Distributor TD-52U & TD-59U (External Coil) TD52
94-95 2156cc with TEC Distributor TD-31U, TD-34U & TD-58U TD31
94-95 2200cc with Hitachi Distributor D4T92-04 w/Two Plugs HT01
94-95 2200cc with Hitachi Distributor D4T92-04 w/One Plug
He order TD31 distributor, Richporter customer service didn't respond to my email.
Old Sep 24, 2007 | 05:50 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: Install an internal coil distributor on an accord that was using an external coil? (Sprayteg)
Do you work at a shop?? Your customer wants to save money but bought a diffrent part?? Hell with that ,tell him either get the right part or go elsewhere.
Old Sep 25, 2007 | 11:55 AM
Grandhustleman86's Avatar
Default Re: Install an internal coil distributor on an accord that was using an external coil? (cb7-R)
Sounds like your customer got a Prelude Dizzy....because if im not mistaken the Accord dizzy's dont have internal coils those years....at least with my f22 dizzy no internal coil....my h22a had an internal coil in the dizzy when I recieved it and after having going thru 2 in 7 months i decided to run the accord dizzy with an external coil....MSD Blaster to be exact....no problems since so my question is why did he order an internal coil dizzy?
now with the Vtec f22b's im not sure on the coil issue....possibly might have a internal coil....
He should be running your parts anyways....IMO
Old Sep 25, 2007 | 02:34 PM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
Default Re: Install an internal coil distributor on an accord that was using an external coil? (Grandhustlem
the F22b1 has an internal coil....
Modified by I got the CD5 Jeebies! at 7:13 PM 9/26/2007
Old Sep 25, 2007 | 08:17 PM
^^^ good call man....thanks for the info....I wasnt really for sure....
Old Sep 26, 2007 | 04:13 AM
TouringAccord's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I got the CD5 Jeebies! &raquo;</TD></TR><TR><TD CLASS="quote">the F22b2 has an internal coil....</TD></TR></TABLE>
uhh... you sure?
I know the F22B1 is an internal coil but I'm almost positive that the F22B2 in an external coil.
edit:
I double checked in the manual... the coil test for the F22B1 shows an internal coil and the coil test for a F22B2 shows an external coil.
Old Sep 26, 2007 | 06:08 PM
Sprayteg's Avatar
Finally, it was easy, just have to remove the stock external coil and to plug the black/yel wire to the yellow wire (on the extrenal coil plug). I guess you have to do that too when you swap and H22.
Old Sep 26, 2007 | 06:12 PM
whoops you are absolutly right..I had em backwards in my head!!!!! I had a USDM H22 in my car which is a external coil and then I put the F22b1 in my car which is a internal coil but I had to still use a external coil...I was thinkking about all this when I posted my response and got all confused.....
Old Apr 14, 2020 | 09:20 AM
Lilcv's Avatar
so you mean take out the wires and put them in together?
RSX2SIcivic
Oct 27, 2008 11:08 PM
b20turbocivic
Apr 25, 2008 08:54 PM
90babyblue
Dec 9, 2004 05:58 PM
bluedelsol
Aug 29, 2002 05:03 AM
