Green wire for turbo timer? If we need it, where does it go?
I'm about to install a Sard turbo timer I got off a buddy for super cheap, and I plan to just splice into my stereo wires for the 12v (red) and acc (blue) but I was looking in a GReddy instruction booklet (mine are in japanese) and the green wire is for cars w/ a 2nd ignition wire or something like that, do we still use the green wire?
If we do, what wire does it tap into? Also, if you know, what color it is. Thanks a ton
I believe the wire you're talking about is the kill wire. You hook it up to either the parking brake or the clutch sensor so no one can steal your car. ie they release the parking brake or push in the clutch depending which one you have it hooked up to and it shuts off the turbo timer, which in turn turns off the car.
