New ecu-no fry
Old Sep 24, 2007 | 10:25 AM
fatboi07's Avatar
Default New ecu-no fry
How exactly do i go about installing my new ecu? As far as i know 1.) unplug negative batt cable 2.) unplug old ecu 3.) plug in new 4.) negative back on 5.) cross fingers and hope it starts. lol. <All that sound about right?
Old Sep 24, 2007 | 10:52 AM
fatboi07's Avatar
bump for helpage.
Old Sep 24, 2007 | 11:09 AM
97Ej6mike's Avatar
As far as i know, no disconnections need to be made. Just plug the green plug (has power) in last.
Old Sep 24, 2007 | 11:25 AM
fatboi07's Avatar
green plug? mine has three. A blue one in the middle and gray on each side.
Old Sep 24, 2007 | 11:28 AM
97Ej6mike's Avatar
Default Re: (fatboi07)
As long as your car is off, you can just plug it in as it is, it wont fry anything.
Old Sep 24, 2007 | 11:33 AM
hondaman1320's Avatar
You can disconnect the battery, plug the ecu in, put you're battery cable on, and you are done. I don't even disconnect the battery most of the time, just swap ecu's, but thats me.
Old Sep 24, 2007 | 11:35 AM
97Ej6mike's Avatar
Default Re: (hondaman1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaman1320 &raquo;</TD></TR><TR><TD CLASS="quote">You can disconnect the battery, plug the ecu in, put you're battery cable on, and you are done. I don't even disconnect the battery most of the time, just swap ecu's, but thats me.</TD></TR></TABLE>
X2, never heard of it frying an ecu from that.
But if you feel compelled to do so, then disconnect your battery, or even easier, just remove the Fuse.
Old Sep 24, 2007 | 02:43 PM
Default Re: (97Ej6mike)
THC07
Dec 12, 2005 03:14 PM
towns
Dec 9, 2004 03:30 PM
S13 slide
Aug 11, 2003 03:35 PM
jermothedrunk
May 29, 2002 10:04 PM
