Is this cat for a b16 header?
Old Sep 24, 2007 | 10:13 AM
89civicdx's Avatar
Default Is this cat for a b16 header?
Will this cat fit on a b16 header? Are all the donut flanges on these cats the same size or different?
Thanks
Modified by 89civicdx at 3:18 PM 9/24/2007
Old Sep 24, 2007 | 11:16 AM
gringo7718's Avatar
Default Re: Is this cat for a b16 header? (89civicdx)
i am using my stock 91 CRX DX catalytic on my car with a b16 and a factory header. i believe the fartory b series header collector is about 2.0" - 2.1" in diameter.
Old Sep 24, 2007 | 12:25 PM
89civicdx's Avatar
Default Re: Is this cat for a b16 header? (gringo7718)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gringo7718 &raquo;</TD></TR><TR><TD CLASS="quote">i am using my stock 91 CRX DX catalytic on my car with a b16 and a factory header. i believe the fartory b series header collector is about 2.0" - 2.1" in diameter.</TD></TR></TABLE>
Thanks very much
So that donut flange is the same for both B and D and fit aftermarket headers too?
thanks
Modified by 89civicdx at 3:21 PM 9/24/2007
Old Sep 24, 2007 | 01:12 PM
RockinthEFhatch's Avatar
if it fits on the exhaust it's for it.... there's no such thing as a "d-series/b-series" cat
Old Sep 24, 2007 | 01:18 PM
89civicdx's Avatar
Default Re: Is this cat for a b16 header? (RockinthEFhatch)
What does that mean? So a cat from a Type R is the same as a cat from a 88 crx si with a d16?
Is the donut flange the same size for both? Don't think about the answer too much guys...just post if you know all these D or B cats have the same size donut flange size or not.
I don't have anything with me to test out so just going by pictures right now.
Modified by 89civicdx at 3:23 PM 9/24/2007
Old Sep 24, 2007 | 03:37 PM
Crx Jimmy's Avatar
well I bought a crx si donut gasket and it fit fine on my US type R header. so it should be fine
Old Sep 24, 2007 | 04:02 PM
RCautoworks's Avatar
It should work but I know some of the older headers have the head flange on reversed, so you have to rotate the cat 180 degres, this would cause problems with the flange on the back side.
Old Sep 24, 2007 | 04:05 PM
89civicdx's Avatar
Default Re: Is this cat for a b16 header? (RCautoworks)
Ok thanks guys for the info
recon23
Jul 13, 2009 05:10 PM
crazyguy
Jun 14, 2007 07:52 AM
T3k C
Mar 30, 2006 01:17 PM
punx04
Sep 4, 2005 12:11 PM
civictildeath
Oct 25, 2004 09:11 PM
