Lights dimming? Not hitting VTEC?
Old Sep 24, 2007 | 09:53 AM
1fast_Shoebox's Avatar
Default Lights dimming? Not hitting VTEC?
I have a 91 civic hatch with a fresh b16.
I was driving home the other night and i noticed my lights got real dim.
First thought- Alternator.
hit the clutch revved up, sounded real sick.
down shifted and beat it like a $2 crack *****. Mis fires like crazy. cant even hit vtec.
When my brights are on my turn signals did not work. The radio cut off. tach went crazy. shift light illuminating the place.
Then all of a sudden my lights got real bright. engine pulled harder than ever before. Almost like it was overcharging.
I know all of the grounds are good. When i did the engine swap i ran fresh 4 gauge grounds.
Any one else havin this problem?
Any suggestions?
Doesn't seem to be the alternator. Had that tested at Advance.
Old Sep 24, 2007 | 10:12 AM
Tyte-S's Avatar
Default Re: Lights dimming? Not hitting VTEC? (1fast_Shoebox)
Short, bad ground or you have a draw somewhere. Rent a DVOM from autozone and test it. Sounds a pretty crazy. Thats all i can suggest for now. Sorry
Old Sep 24, 2007 | 10:29 AM
thegooddoctorceretti's Avatar
i had the same problem on my 91 si crx, check the coil. thats exactly what mine did and thats what it was
Ghett0_ed
Jun 22, 2010 01:39 PM
weavertime1
13
Jan 26, 2009 07:14 PM
91ef8sir
Aug 2, 2006 03:57 PM
rudeman85
Mar 20, 2005 09:10 AM
