jdm headlights ef....
`i am thinking about buying a set of one piece JDM headlights for my ef sedan....however i DO NOT have the jdm front end ..... is it possible to make them fit or am i going to waste money on the headlights ? i would greatly appreciate some help on this be4 i waste my time and money... just an FYI i am getting them for a really great price... ( 100.00 ) please let m eknow ASAP what you guys think....
thanks
thanks
JDM SiR headlights are a bit longer and angled differently where the hood meets them,your USDM hood wont even come close to closing with these lights on.I think what you need are JDM EF ZC headlights,they're almost identical to the SiR lights but supposedly work with USDM parts,you may want to verify using a search engine though.Dont forget you'll need an H4H conversion harness,Password:JDM sells them like $25.
Right on point, the ZC headlight are the exact same shape as USDM Civic/CRX headlights but are single bulb. Unfortunately, the OP has a SEDAN and not a hatchback/CRX.
http://images.craigslist.org/0...6.jpg
here are the headlights .... i dont know if they are zc or sir.. please let me know thanks sooo much
The only one piece headlights for the 88-91 body style were from the JDM sedan, CRX and hatch still had seperate corners. Other than the hood and grill, there is no difference. Check the appearance forum, I believe they have a thread with EF sedans and if I remember correctly I think I had seen some with the USDM hood/grill and the JDM one piece lights.
Yikes, I didn't realize the gaps were like that. IMO you should get a hold of the matching hood, grill, filler, and fenders then. But if you don't mind the gaps, then do that mod in the link spastik posted.
http://image.bayimg.com/eahnoaabb.jpg
here is my ef sedan let me know your thoughts on it. i appreciate all the support and help; you guys are cool
Did you get a chance to see the EF Sedan thread? If you see the difference between the two fronts, that should be enough to decide whether or not to get the headlights.
thaks i will look. also on another note... will the ef hatch front end fit? * fenders hood bumber lights * basicly the whole jdm conversion for a hatch? mabee that will give me a cleaner look and be less head ache
tonylovesjdmEF9
Jul 31, 2011 01:29 PM
EFhatchSi
Nov 21, 2006 04:27 PM
88, conversion, difference, ef, end, front, hatch, head, headlight, honda, jdm, lights, modification, piece, sedan
fyi
