rear brake swap Q
i searched and found no info..i have a gsr brake swap(front and rear)
there going on my 94 4 door..i was wondering do i order ss brake lines for an integra? and also will the front and rear control arms on my civic work? or do i need integra lcas? i also forgot to ask..if im using this setup..will 14' rims fit?
thanks in advance
thanks in advance
yes on the brake lines, i swapped the stock brake lines from the integra onto my civic so they will fit.
lca's will fit, but i'd get the rears anyway so you can run a sway bar.
what 14's?
i know hx 14's won't fit the front unless you grind down the caliper.
but stock 14 inch steelies will fit the front.
i guess it depends on the rim..
what 14's?
FuNkDrSpOt
May 10, 2008 08:52 AM
