rear brake swap Q
Old 09-24-2007, 12:55 AM
eg8guy's Avatar
Default rear brake swap Q
i searched and found no info..i have a gsr brake swap(front and rear)
there going on my 94 4 door..i was wondering do i order ss brake lines for an integra? and also will the front and rear control arms on my civic work? or do i need integra lcas? i also forgot to ask..if im using this setup..will 14' rims fit?
thanks in advance
Old 09-24-2007, 03:59 AM
instrument's Avatar
yes on the brake lines, i swapped the stock brake lines from the integra onto my civic so they will fit.
lca's will fit, but i'd get the rears anyway so you can run a sway bar.
what 14's?
i know hx 14's won't fit the front unless you grind down the caliper.
but stock 14 inch steelies will fit the front.
i guess it depends on the rim..
Old 09-24-2007, 08:57 AM
eg8guy's Avatar
so i should order integra lcas? and the 14's are just some off brand,they look like smaller r32 volkswagen rims.
lv6l
11-30-2008 09:57 PM
FuNkDrSpOt
05-10-2008 08:52 AM
TotalBalance
Suspension & Brakes
11-06-2007 09:58 AM
Stroker
10-18-2004 06:44 AM
b20ek
08-05-2003 06:50 PM
Quick Reply: rear brake swap Q
