help engine tick is driving me nuts!!
hey everyone i have a 2000 civic si thats totally stock havnt done anything yet. problem is that i hear this tick noise when im driving and i step on the gas or take my foot off the gas. it isnt a loud noise and it doesnt seem to affect the way the car drives. acceleration is fine no hesitation or backfires but my friend and i cant seem to figure out what the expletive this noise is. someone please help me!
Do a tune up, check timing, use 91 or higher octane, if still making noise, adjust valves, all my B-series cars have made a ticking sound, not to loud, but noticeable to me, but never had any problems, how loud is the TICKING???
well its not the idle ticking noise i know that one. the ticking isnt really loud at all its only a slight noise that i heard and then asked my friend about but like i said we cant figure out what it is. ive been using mid grade (89) for gas.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jrap1243 »</TD></TR><TR><TD CLASS="quote">hey everyone i have a 2000 civic si thats totally stock havnt done anything yet. problem is that i hear this tick noise when im driving and i step on the gas or take my foot off the gas. it isnt a loud noise and it doesnt seem to affect the way the car drives. acceleration is fine no hesitation or backfires but my friend and i cant seem to figure out what the expletive this noise is. someone please help me!</TD></TR></TABLE>
I have had a similar problem but my ticking is only present while im driving and in gear and the car is around 2.5 - 3.5k
Whenever i had oil changes it would get rid of it until the oil burned off
I don't know what it is but I did take my cat shield off and it helped with the noise but didn't eliminate it. I think it's either an o2 sensor clearance issue, debris around the heat shield and the mounts or maybe something stuck in your tranny mount.
Everything that i did to get rid of the noise reduced it but didn't get rid of it so i think there are a couple of things moving around. Probably same for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yoffer »</TD></TR><TR><TD CLASS="quote">A tune up includes a valve adjustment. Honda reccomends doing one every 30k miles.</TD></TR></TABLE>
No it doesn't. A valve INSPECTION is recommended but a valve adjustment is every 90k .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragonfly2k3 »</TD></TR><TR><TD CLASS="quote">a very small exhaust leak between head/header or header/cat can cause a sound similar to valve noise. </TD></TR></TABLE>
Good catch. I also thought it was the coupling between my header and my exhaust. Make sure everything is tightened down.
Wait for the noise to start and then drive your car up on a ramp and put some grease on the exhaust couplings.....see if that works.
I forgot to mention that one thing i did was add and extra exhaust hanger to my car since my DC Sports exhaust came with 2 hangers around the shifter. This really helped out....so maybe what we're both describing IS an exhaust leak...because It def didn't seem mechanical.
GOod luck.
GOod luck.
so i posted this a long time ago. i finally found out what the problem was. it was my axle the ticking noise i was hearing was the axle jerking. so not sucha hard fix cost me like 70 bucks for the part and i had a friend of mine help me fix it. but if i ever hear another type of ticking i will have an idea of what it is
thanks everyone
thanks everyone
Azxster
Sep 28, 2007 08:16 PM
Mi2age
Jun 25, 2007 07:54 PM
