Stupid Rain...Carbon Fiber Advice
Ok ive been seaching and have found many different ways but i wanna know if any are even worth it...
What Happened is it recently rained and the rain sat on the hood for like 2 hours in the sun...Seems as if the rain drops and puddles magnified the suns rays and oxidized my Carbon Fiber Seibon Hood like super quick
Its everywhere and i don't know what i should do...
Ive herd to use Nu Finish on it and i don't think the 3m stuff will be strong enough since it says light oxidation...I can also just get if sanded and re-cleared for $60...whats my best option here...really would rather not have to get it re cleared tho...
PIX: Is this Salvageable??
STUPID RAIN!!!
Its everywhere and i don't know what i should do...Ive herd to use Nu Finish on it and i don't think the 3m stuff will be strong enough since it says light oxidation...I can also just get if sanded and re-cleared for $60...whats my best option here...really would rather not have to get it re cleared tho...
STUPID RAIN!!!
That looks like about sixty-eight shades of awful.
Unfortunately, unless it was acid rain I don't think here is any way that that happened just because of the water sitting on your hood. That whole thing about water droplets magnifying the suns rays and pitting your clearcoat is just marketing bullshit.
What it looks like is either simply oxidation (bad) or CC failure (worse). If it is simply oxidation you should be able to correct it by using a buffer, DA or Rotary, and a light to medium polish.
However if it is clearcoat failure, you are most likely going to have to have it stripped and re-cleared.
Edit: I just took another look at your pictures, are you sure those aren't simply hard-water spots? Did water pool onto your hood, from the run off of a roof drain or something? Usually if water gets onto your car and is allowed to bake in the sun it will dry leaving lots of water spots, but if it rained then shines real quick I could see some standing water leaving those types of marks. Try washing it first, that just might solve your problem right there
Either way after it is fixed make sure that you wax your car and maintain the integrity of your paint. Carbon fiber pieces are just as susceptible to the harsh elements as are any other painted parts of your car.
You could try wetsanding it with 2000-grit wet/dry sandpaper then use a rubbing compound to buff it out afterward. I think I used a 3M cutting compound. It made it look better for a while but the clear coat problems came back on mine even worse than before. Must have just been a cheap clear. I was under the impression that Seibon made really high quality products though...
Many carbon fiber mfr's advertise UV protectant coating. However, if you want it to last have it cleared with at least 2 coats of quality clear. Parts like a hood allow the clear to flow out pretty flat, so a quick de-nib is all the buffing it should need.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -NA-aLL-thE-wAy- »</TD></TR><TR><TD CLASS="quote">Note to self: Don't buy a c/f hood.
There are way too many of these threads.
For Real Tho...
I did try to wash is but no luck...ill try a basic buff first maybe there just spots stuck on really good...thanks guys
</TD></TR></TABLE>For Real Tho...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jman8108 »</TD></TR><TR><TD CLASS="quote">Ive heard for this type of thing Turtle Rubbing Compound with a buffer works great.</TD></TR></TABLE>
LOL @ turtle wax products
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E-Rok »</TD></TR><TR><TD CLASS="quote">
LOL @ turtle wax products</TD></TR></TABLE>
Something wrong wit the turtle? Ive never had a problem but does it harm carbon fiber or sumthin? Its not like it matters since it looks horrible already lol
i dont want to sound like one of those guys that says "search it"...... but i know that there are threads out there of people that have sanded and re-cleared and/or buffed their CF hoods. the posts i found showed some nice results....... but again search for it. if i can find some good ones, ill post them here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeucesWild »</TD></TR><TR><TD CLASS="quote">i dont want to sound like one of those guys that says "search it"...... but i know that there are threads out there of people that have sanded and re-cleared and/or buffed their CF hoods. the posts i found showed some nice results....... but again search for it. if i can find some good ones, ill post them here.</TD></TR></TABLE>
ok not to be rude but if you read the OP you will see i have searched and also said i did find many options so i know whats out there...im just asking what the best path is since its a seibon hood and i dont wanna wreck it anymore than it is..thanks anyways Deuce
