Turbonetics turbo, hondata, valves FS *cheap*
First is a turbo ive been holding onto for a while just figured its time to let go. its a turbonetics t3/t04b. now i have done a **** ton of research on this guy, this is what i have found. I believe it to be a to4b s-3 trim compressor (it even has an "s" stamped on the compressor outlet. it has a ~48mm inducer, ~76mm exducer and flows about 37 lbs/min. its basically the next step up from a t3 super 60 compressor and is the first t4 family compressor. the turbine is a std./stage 1 with an exducer coming in at just under 1.9" (technically 1.898") and a .48 a/r turbine housing. i was told when i got my hands on it that it does in fact have the ceramic ball bearing CHRA, but ive never been able to verify that. it also has a turbonetics 90* bend welded to the outlet. it could be cut of and re-welded in any direction. it also has the oil inlet fitting for a 4 an line i believe. it is oil cooled only so no water line have to be run for an easier install. things to note, it has a few small cracks in the turbine housing, but nothing id be worried about. it also has a chipped tab off of the CHRA (you can see it in the pic its nothing bad at all), but that has nothing to do with the performance. the turbo has no play what so ever "in and out", it is truly in great shape. i have kept it oiled and have the turbine housing loose so they dont fuse togther and it will be easier to fit. $300 shipped :wink:
Ok, ive got a hondata s200b that i have had for a while now, just upgraded to the s300 system as soon as i got this one. i dont have the original box or chipping stuff, just the box with the datalogging cable and a serial to usb port adapter. it does have boost/3 step/datalogging ablity that you used to have to "upgrade" to. $100 shipped SOLD!!!
i also still have manley 31mm (1mm over) intake valves brand new. please make me an offer and get these off my hands!
Modified by FactionR at 9:07 PM 9/23/2007
Modified by FactionR at 9:09 PM 9/23/2007
Modified by FactionR at 6:57 PM 9/28/2007
IN VTEC
Dec 20, 2007 02:20 AM
FactionR
Dec 18, 2007 01:12 AM
