best budget motor ?'s please help
ok so the gsr swap fell thru.
i gott about 1000 bucks.. maybe a lil bit more. and i want a dohc vtec motor.. i was thikin lsvtec or b20vtec. what u guys think would be the best set up for the money.. i gotta 94 hatch..
so u have buget for your motor swap..that should be hard to find the right motor u within your budget.but are u planning to do the swap by yourself? $500~$700 to have a shop done the swap
yeah i do it myself.. i gotta lift and stuff etc.. its jsut idk what i wanna do.. liek type r internals in ls block. with gsr head.. i allready got a b16 tranny with ls 5th gear.. im jsut wanting a strong stock set up.. liek my boy had a b20vtec in his and that mug moved.. just wanting somethign that is gona be strong but reliable
true. but b20 have the better tourqe. thats what im tryin to fig out.. i herd b20 with gsr head put liek 200 stock to he wheels. just tryin to fig out what otehr people with more experican think
A Correctly done LS/Vtec or b20Vtec will cost you alot more than a grand.
Cheap LS Block $150
Cheap b16 Head $350
Conversion Kit $200
ITR/GSR oil pump $80
Water Pump/Timing belt kit $150
Used Knock Sensor $40
Machine work $50-100
Piston Rings $50
New Gaskets/Seals $100
Thats not even a reliable build either thats just basics all at really cheap prices you'd be lucky to get. As with every build theres all the small things that add up after awhile.
Buy a used b20 and some mild cams and youll have plenty of fun in it.
Cheap LS Block $150
Cheap b16 Head $350
Conversion Kit $200
Piston Rings $50
stock b20 with gsr head IS NOT 200whp
its more lie 165-170whp
a b20 block with those 84mm itr style pistons and a gsr head would give you 180-190whp.
why gsr head.
b16 head is cheaper. get itr valve springs and some cams decent header and intake and youll make 200whp no problem
why gsr head.
jdm$product$
12
Mar 24, 2010 02:22 PM
DRAG14ciVHBKSI
Aug 8, 2002 11:00 AM
