runs one day and not the next
I got codes for O2 and fuel injector failure....replaced O2 sensor, fuel filter, removed and cleaned the throttle body and all that. Car ran but kept throwing codes, no CEL. Next day, CEL comes on and same codes....before I replace the injectors, is there anything else that could be messed up? ECU? Just doesn't make sense why the car ran with codes, and now with CEL it trips the ECU and won't let the car start...resetting the ECU did nothing
Any ideas???
Any ideas???
I will have to ck the pins on the harness going to the ecu, make sure they are not pushed in...the pins are fine at the injector end
No friends with same car
Legion
Jun 12, 2011 06:36 AM
RACEPAK
Nov 24, 2007 02:45 PM
