B16A With Hydro Tranny in an EF hatch
Old Sep 23, 2007 | 03:44 PM
bkmc24's Avatar
Default B16A With Hydro Tranny in an EF hatch
So i have now a 92 4 door civic with a JDM B16A in it. the shell is junk and i feel completely unsafe in it. The EF i am getting is already OBD swapped and Multi-port swapped. What else do i need to get this motor to work in the hatch? I have been looking around and getting some info but most is about the Cable tranny instead of hydro. Thanks!
Ben
Old Sep 23, 2007 | 03:53 PM
CRX Toad's Avatar
Default Re: B16A With Hydro Tranny in an EF hatch (bkmc24)
HaSport makes a hydro conversion for B-series. Other than that it is all the same.
Old Sep 23, 2007 | 04:01 PM
bkmc24's Avatar
Default Re: B16A With Hydro Tranny in an EF hatch (CRX Toad)
Okay, well hypothetically, this guy is FOS, and the car isnt OBD swapped, how easy is that? i have done the Multi-port swap before but not an OBD.
Old Sep 23, 2007 | 04:02 PM
CRX Toad's Avatar
People convert OBD1 everyday there are conversion harness and ECU. Check out the FAQ it details it all out.
Old Sep 23, 2007 | 04:11 PM
bkmc24's Avatar
Okay so the mount from the EG should work in the Ef other than the Tranny mounts from HASport?
Old Sep 23, 2007 | 04:13 PM
CRX Toad's Avatar
In order to get the B in there you are going to need mount kit. So basically you are going to buy the entire mount kit from Hasport. http://www.hasport.com/product...2.htm
Also going to need linkage, either make your own or buy.
Old Sep 23, 2007 | 04:38 PM
The_Undertaker's Avatar
75.168.105.221
To make your own linkage obtain a ls shift linkage and cut 1 in and weld it back. Try to cut in an area where its straight and no curve.
Old Sep 25, 2007 | 09:15 AM
bkmc24's Avatar
Old Sep 25, 2007 | 09:54 AM
bkmc24's Avatar
So i still need a little more help.
Will my axles from the EG fit in the EF? I already have hasport axles and kind of dont want to have to get more. Also, what harness do i need to use? Basically the whole electrical is what i dont know so if anyone has something that is useful please let me know. thanks.
Ben
Old Sep 25, 2007 | 06:30 PM
bkmc24's Avatar
UP still need help
Old Sep 25, 2007 | 06:46 PM
cheap2's Avatar
hey hey hey,the noob wanna know if it's true that the b16a engine needs to run on premium gas? i can't find the answer
Old Sep 25, 2007 | 06:49 PM
cheap2's Avatar
ok ok ok,the noob find it yes they need
Old Sep 25, 2007 | 07:08 PM
SlapSmak's Avatar
Ben, you will need the HAsport kit for the EF, I dont know if the axles you have will fit, call HA sport on that.
You will need an OBD0-OBD1 ECU Harness, you will need the vtec subharness or just make your own. You can do what I did and use the civic connector and resolder the correct wiring to the B16 Connectors.
There is a TON of info on ef-honda, check that out also.
Good luck. My brother and I swapped a B17 into my EF in 2 days, with full GSR suspension changover and a ton of other work. Just read up and you can get it done.
Old Sep 25, 2007 | 09:31 PM
bkmc24's Avatar
Default Re: B16A With Hydro Tranny in an EF hatch (SlapSmak)
OKay cool, thanks for the help
Old Sep 25, 2007 | 09:33 PM
bkmc24's Avatar
Default Re: B16A With Hydro Tranny in an EF hatch (cheap2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cheap2 &raquo;</TD></TR><TR><TD CLASS="quote">hey hey hey,the noob wanna know if it's true that the b16a engine needs to run on premium gas? i can't find the answer </TD></TR></TABLE>
GTFO jackass. Dont need a selfcentered ***** being stupid.
Simply need my questions answered which they are.
Old Sep 26, 2007 | 05:56 PM
cheap2's Avatar
woo buddy,easy,i'm new in all this,my bad,i will never answer or talk to you in this forum again i'm out of your ******* thread have a good one
Old Sep 26, 2007 | 06:54 PM
bkmc24's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cheap2 &raquo;</TD></TR><TR><TD CLASS="quote">woo buddy,easy,i'm new in all this,my bad,i will never answer or talk to you in this forum again i'm out of your ******* thread have a good one</TD></TR></TABLE>
Well i figured you were someone being an *******, sorry about that.
Old Sep 27, 2007 | 12:33 AM
civickiller's Avatar
you need a da rear bracket but the holes on the bottom bolts need to be bored out to fit a 19mm.
get all hasports mounts with hydro conversion and shift linkage
whatever dist and injector plugs. o2 plug with sensor. integra throttle cable
slowsinglecam
Aug 16, 2011 04:45 PM
SiR eF_4door
Nov 13, 2009 03:16 PM
kpop
Jan 11, 2007 10:32 PM
DIY_Racing
Oct 27, 2004 02:34 PM
Jamison182
May 24, 2003 08:16 AM
