ls/vtec vs fully built b16
I was wondering what would be better for the buck and the long run consider a bacic ls vtec noting wild and a fully built b16 hp/tq it going to be in a em1 and also suggestion on what parts to go wit for the best setup
you'll make more power with an lsvtec because of it's displacement advantage. a b16 would probably be more reliable, but either can be reliable.
your comparing power outputs of a fully built b16 and a basically stock ls/vtec?
my vote goes to ls/vtec...not that the b16 is a bad motor but it will be cheaper to ls/vtec it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ser13 »</TD></TR><TR><TD CLASS="quote">how much power could be expected out of both how much would a ls vtec come out to</TD></TR></TABLE>
it all depends on what you are going to do with them...and since you have an EM1 you already have a VTEC head so all you have to do is find an LS bottom end and follow the appropriate steps to put the vtec head on the block. You can find an LS block for dirt cheap if you know where to look, i got my complete shortblock for $50
i got mine for free lol. it depends on what u want to put in the bottom end. i have seen a few ls/vtecs using honda parts except for cams make 220whp
When it comes to modifying the LS/VTEC there may be more little pains in the *** when trying to apply a part (meant for a whole original motor) to a "Frankenstein", depending on the part. Plus, with a B16, a stroker kit and some used OEM parts will get it's horsepower and torque up significantly and is far easier than building a Frank motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtownek9 »</TD></TR><TR><TD CLASS="quote">can't you stroke the b16 to get the same displacement as the ls?</TD></TR></TABLE>
with boring and stroking
