Hickam's For sale thread. updated regularly
FOR SALE: WILL ACCEPT REASONABLE OFFERS!!! ALSO INTERESTED IN TRADES
JDM B16 p73 Intake Manifold $125
AEM Cam gears 2 of them for b-series $95
Chipped p28 ECU perfect for hondata, uber, crome, etc $150
Chipped p06 ECU perfect for hondata, uber, crome, etc $100
Chipped P75 ECU perfect for hondata, uber, crome, etc. The j1 jumper that jumps the chip from the ecu has been cut to run on a stock map since a chip wasn't available to run a friends car. Should be able to hook back up to run chip $100
Blox front camber kit- about 2k on them $90
Custom Harness bar will fit 92-00 civic, not sure about integras $200
Fast turbo fuel line kit steel braided hose with -6an fittings to go from stock fuel filter to fuel rail $50
Momo steering wheel comes with hub for 92-95 civic and 94-01 teg. $150
Gauge cluster dual gauge pod mounts (2) 52mm gauges around the gauge cluster in a 94-01 Integra $30
Catchcan for your battery tray cut down your stock battery tie down hooks and it comes with a catch can brace, can add fittings or whatever you want. was using regular rubber hose, but -AN line can also be used $125
Can also custom fabricate a catch can with any dimensions you want. Just PM me
Mishimoto Aluminum radiator thick 2" core $150
Turbo parts will take trades, let me know what you have
Intercooler piping with Greddy RS Bov $325
Intercooler 24x9x3 fits perfect behind the grill of your bumper $150
RC 550cc injectors don't need a resistor box for those that are asking $200
LS oil pan tapped for return line $40
Fast turbo oil feed line NEW $40
Turbosmart boost controller NEW and red annodized. $50
Autometer oil pressure gauge needs a oil pressure sensor $15
EG
Blue EG steering wheel w/bag $20
Rear speaker brackets for hatch $15
Rear carpet behind seats in hatch $50
94-01 integra
LS gauge cluster, manual with 130k. $70
AC climate control unit $30
white Blower box $25
blower $20
glove box $20
heater core $20
Black integra carpet $50
black shifter console $20
black cloth armrest $20
foam piece under shifter console $15
glove box $20
LS crank with spun rod bearing $40
12" L5 solobaric sub in good size box, fit perfect in the back of my hatch and Kicker 750.1 mono amp. Only used for a month then took it out. Have everything to hook it up $300
1993 Civic Hatch DX has Clean title. $1,500. STRAIGHT BODY! I can either sell it will all of the interior or gutted, you choose. Most of the plastic panels have been covered in TWEED, looks badass. Make me an offer. Would like to trade it for anything really, just make some offers. Needs complete motor swap and seats. Was painted flat black, not your usual primer job. Door jams and all. PERFECT TOY PROJECT CAR
Will come with stock shocks and stock black dash installed. Will need civic gauge cluster. Has had the battery relocated to rear, but can put back to stock if that is how you want it. Can also put the heater core and blower back under the dash with no problem. Will come with steelies and not the SI wheels. Has tint all the way around that was done just christmas time of last year. Walbro 255lph fuel pump installed, stainless braided brake lines, brembo cross cross drilled rotors, momo steering wheel (not the one in the pics)
Pinball machine traded to QFAST817
Modified by HickamHatch at 10:50 PM 9/23/2007
EG
94-01 integra
blower $20
glove box $20
heater core $20
glove box $20
mtber
Performance
2921
Dec 10, 2017 02:04 PM
mtber
Jul 14, 2011 05:53 AM
92jdmhatch
May 2, 2007 09:54 AM
