How to tell if my injector went out?
Ive got a set of PTE 1000cc injectors wired through a resistor box. My car is only running on 3 cylinders. Its got spark and fuel to the other cylinders obivously as well as spark on #4, but the #4 runner doesnt heat up at all and i can pull the injector clip and plug wire on #4 and it doesnt change the way it runs. In 3 cranks it puts down 165lbs of compression. So the only thing that could be left in an injector. Is there a way to check if an injector is bad. I tested Ohms and their all 2.6. I thought PTE injectors were supposed to be pretty reliable. Any input?
turboteg2nv
Dec 2, 2004 03:53 PM
