Window Regulator/motor left rear 92 Accord needed
Old Sep 23, 2007 | 07:41 AM
kabhatti's Avatar
Default Window Regulator/motor left rear 92 Accord needed
My left rear window won't go the whole way up, looks like I need the regulator, where is a good place to get a good one at a good price. Thanks.
Kalim
Old Sep 23, 2007 | 10:15 AM
standbackimapro's Avatar
Rockauto.com
Old Mar 29, 2008 | 11:48 AM
hmbtjc29's Avatar
Default Re: (standbackimapro)
It' may be a little late for this, but just a tip on the rear regs on a CB. It seems that the weak spot in these it the plastic cable guide on the top. Both of mine were broken, but everything else, motor, cables, was good. I looked everywhere for new ones...flat not available. I went to a junkyard and found two of the cable guides that were unscathed (good luck) and just rebuilt mine. For good measure I epoxied the crap out of the new ones on the weak spots and on the curved part on the front of the plastic piece and also epoxied it onto the regulator, making it much more difficult to break. The kicker on this, is that the motor has a ratchet mechanism and tightens up the cable when the guide breaks and you won't be able to put the cables in the new cable guides. You have to open up the motor and pop the two piece wheel where the cables wrap around and release the tension enough to slacken the cable and then tighten it back up. It's a pain, but well worth it to save a lot of bucks on rear regs. Mine work good as new.
user114
Dec 16, 2012 08:04 PM
BLKFLSH
Oct 10, 2012 03:09 AM
