nlr gsxr 1000 turbo manifold
I dont get how the wastegate works... or is this manifold not divided. the turbo definitely doesnt look to be.
plus whats the firing order? looks like they paired the wrong cylinders.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RTErnie »</TD></TR><TR><TD CLASS="quote">I dont get how the wastegate works... or is this manifold not divided. the turbo definitely doesnt look to be.
plus whats the firing order? looks like they paired the wrong cylinders.</TD></TR></TABLE>
they welded the turbine housing it looks like
looks awesome! what kind of bit did you use to drill into the cast iron? and what kind of filler did you use to weld the stainless to the cast?
thank you.
thank you.
damn yea it always shows when you spend your time on fitment. now the real question is....do you charge hourly or for the whole job LOL. seems to be a loose loose situation most of the time!
no issues with the balance of the bike? being that the turbo is not centered? or does the WG and DP and dumptube counter balance it enough?
sick fab BTW
sick fab BTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r »</TD></TR><TR><TD CLASS="quote">no issues with the balance of the bike? being that the turbo is not centered? or does the WG and DP and dumptube counter balance it enough?
sick fab BTW</TD></TR></TABLE>
I'm pretty sure he's going to be shifting all his weight up front to keep it from 12 o'clocking!
The 1000 have that stupid balance shaft in the front of the motor its too bad. Cause on the 600 and 750 u can push the turbo back about 3 "
Nice work tho
Nice work tho
there is a local who hits the track with a bike that has a 40r on it. it's retarded, just like this bike. you couldn't pay me to lay on the throttle.
