92-95 Civic rad in 89 Rex!!!
ok, my rad has a hole in it. I saw the civic rads and they are a whole lot smaller. I plan on going turbo a little later on, so it would give me some more room for the turbo. My question is if I get the civic rad what will I need to get it to fit??? Are all civic model rads the same (92-95)??? How would I get the fan to work??? and what hoses would i need??? thx for the help!
just get an after market fan at pepboys or autozone and custom a bracket on top to hold the rad in place.... ur stock hose should fit on the rad fine... the 4dr rad is a little thicker than the 2dr... either would be good...
if ur gonna use this rad u can't have a/c... the other fan is for the a/c... wiring is easy positive to positive neg to neg... either that or cut the plug on ur oem fan and connect it to the new 1....
neon rad
[Modified by .:s h a w n D:., 3:49 PM 6/18/2002]
I was told that if I make a bracket to make it angle back like an inch and a half that it would work??? Is this true??? then the hood would close with no problems!
South Bay Surfer
Jan 31, 2003 06:32 PM
