Engine will not start afeter straight swap. No spark
Old Sep 22, 2007 | 10:10 PM
djnikko's Avatar
Default Engine will not start afeter straight swap. No spark
I have just swapped in a new d15b2 engine into my EG civic and used the core part of the harness that was attached to the new block which had all the same part number (P04). The engine looked pretty new and my old engine is rusted '94 jobby, could it be the wrong OBD dizzy if the new engine is indeed alot newer? Im doubting it but maybe. As above im getting no spark but it is cranking and soaking the plugs in petrol. Anyone got any ideas?
Old Sep 23, 2007 | 05:40 PM
rookiepains's Avatar
Default Re: Engine will not start afeter straight swap. No spark (djnikko)
make sure all your grounds are perfectly grounded
Old Sep 27, 2007 | 06:45 AM
djnikko's Avatar
Default Re: Engine will not start afeter straight swap. No spark (rookiepains)
The cambelt was snapped on the donor engine :S luckily its all ok with a new belt on. I shall check the valves and pistons for damage in a couple of weeks but its running fine for now. Just thought id report back
Old Sep 27, 2007 | 02:56 PM
toqeer1986's Avatar
it will be your ecu wiring the icm chek if theres power going to it
Old Sep 28, 2007 | 02:16 AM
djnikko's Avatar
Default Re: (toqeer1986)
Did you not see the post above? Its running fine now. The cam belt was snapped and I forgot to check this prior to putting the new engine in
nonoyc
Oct 9, 2017 04:07 AM
RO_SUNNY
Honda CR-V & Element
Mar 1, 2016 01:34 PM
blackfury
12
Nov 8, 2009 06:24 AM
justvisiting
Aug 9, 2009 08:27 PM
EJ1 wilcox
Aug 29, 2005 09:08 AM
