ZC vtec timing help!
I have a ZC Vtec on my CRX, but I need to put the timing on it. Does anyone have any picture of how everything is suppose to look when it's on time? I need to know how the pistons, valves, and pulleys are suppose to look... Or a diagram.
I only changed the engine and I have all CRX stock parts... it was just the block that I changed. The car was working fine at 1st, but then the RPM went low and the car turn off I check everything and the screw that the cam gear had was loose so I tighten it. The car turn on, for a while, but it turn off again. Oh and I was wondering of what happened if the cam shaft stayed still and the cam gear pulley spin. What would happened to the engine?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silencer1503 »</TD></TR><TR><TD CLASS="quote">I only changed the engine and I have all CRX stock parts... it was just the block that I changed. The car was working fine at 1st, but then the RPM went low and the car turn off I check everything and the screw that the cam gear had was loose so I tighten it. The car turn on, for a while, but it turn off again. Oh and I was wondering of what happened if the cam shaft stayed still and the cam gear pulley spin. What would happened to the engine?</TD></TR></TABLE>
Your valves would stay open and your pistons would smash them to pieces.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1988hondacrxsiR1 »</TD></TR><TR><TD CLASS="quote">whoa zc vtec? It is dohc or sohc? And are you stamp on block says ZC?</TD></TR></TABLE>
There are many different ZC's. Including the SOHC VTEC ZC.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Max Kling »</TD></TR><TR><TD CLASS="quote">
There are many different ZC's. Including the SOHC VTEC ZC. </TD></TR></TABLE>
Wheren't sohc vtec engines all D15/D16's? I didnt think any block stamped with ZC came with VTEC.
Thanks for the link Max Kling. Do you know or does anyone else know what chassis these engines came standard in? Id assume either integra or civic, but i'd like to know which models.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ~sp33~ »</TD></TR><TR><TD CLASS="quote">
Your valves would stay open and your pistons would smash them to pieces.</TD></TR></TABLE>
Ok this happened to me the cam gear was spinning, but the cam shaft didn't. I already took of the head, but my valve weren't smashed to pieces... They just got bended.
Ok this happened to me the cam gear was spinning, but the cam shaft didn't. I already took of the head, but my valve weren't smashed to pieces... They just got bended.</TD></TR></TABLE>
well it depends on how long its running for as to how smashed they get. You got lucky.
well it depends on how long its running for as to how smashed they get. You got lucky.</TD></TR></TABLE>
I got lucky? So does that mean it would be better if I just fix the head then to buy a new one?
I got lucky? So does that mean it would be better if I just fix the head then to buy a new one?</TD></TR></TABLE>
You could replace the bent valves. Im just saying that there could have been alot more damage done by what happened to you. Ive seen valves come out of exhausts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El pimp chulo »</TD></TR><TR><TD CLASS="quote">no such thing as zc vtec at all no matter what anyone says</TD></TR></TABLE>
your an idiot, i have one sitting outside, SOHC Vtec 1.6L. Believe that.
as for the OP, your cam has a tooth in it so as long as the cam gear was completly on the cam they would spin together without being torqued down.
make sure you didnt set the timing belt off (check the marks on the crank pully first, make sure its TDC) then check the markes on the timing cover with the marks on your cam gear.
then make sure your dizzy is almost dead vertical on the head (btw, are you running OBD1 or 0?)
it should start, and if it does hit it with the timing gun and adjust to 16degrees.
still wont fire up? do a compression test to see if you mashed up the valves
GL!!
GL!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silencer1503 »</TD></TR><TR><TD CLASS="quote">What is a TDC? </TD></TR></TABLE>
TDC=top dead center.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silencer1503 »</TD></TR><TR><TD CLASS="quote">Oh and my valve are bendted I want to get a new head. </TD></TR></TABLE>
then get a new head and a service manual
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silencer1503 »</TD></TR><TR><TD CLASS="quote">What is a TDC? Oh and my valve are bendted I want to get a new head. </TD></TR></TABLE>
What you need is english classes WTF?! Is every kid this stupid or is it just the stupid ones that come on this forum?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danmdevries »</TD></TR><TR><TD CLASS="quote">
What you need is english classes WTF?! Is every kid this stupid or is it just the stupid ones that come on this forum? </TD></TR></TABLE>
Settle down, atleast this noob has a descent question. There has been some real bad noobies floating around lately.
Tad
22
Feb 23, 2005 01:38 PM
