Is this normal?
Old Sep 22, 2007 | 07:55 PM
TinyTitan's Avatar
Default Is this normal?
Ok guys I just got done rebuilding my motor........I blew out the intake reliefs on #4 piston......and I had what I thought was a head gasket leak
Well I got everything back together, I had my head decked so it is true and so is the block.....I installed a new cometic headgasket with copper spray and well here is what I am seeing
Before all the rebuild happened, under spirited driving I was pushing coolant into the overflow......not like gushing fluid in but some would find it way in there......but eventually go back.....coolant temps never got over 220.
Fast forward to tonight, and under spirited driving again, it again was pushing a little coolant into the overflow......ECT are 190 while driving under full boost.......no smoke, no sign's of anything wrong..
So my question is, is it normal to push a little coolant into the overflow?
Sorry for my noobishness
Old Sep 23, 2007 | 06:11 AM
Hondaruss's Avatar
Default Re: Is this normal? (TinyTitan)
at 190* of EC you should not be pushing coolant out fo the cooling system at all. what kinda head bolts you have and what you torque them to?
Old Sep 23, 2007 | 08:03 AM
TinyTitan's Avatar
Default Re: Is this normal? (Hondaruss)
ARP head studs @ 75 ft lbs
Old Sep 23, 2007 | 11:04 PM
Rd91SiB18ls's Avatar
Sounds normal that's what the overflow is there for, when fluid gets hot it expands
and needs more space when it cools it sucks it back into the engine.
krc91987
Jun 28, 2015 03:51 AM
JDM_SOHC
21
Mar 18, 2010 10:14 PM
A-dub5513
May 18, 2009 04:08 AM
inphin1ty
12
Mar 17, 2008 10:17 PM
boostedNOTHARDLY
Dec 4, 2007 07:27 PM
