Starter Problem?
Old Sep 22, 2007 | 06:55 PM
blaxican05's Avatar
Default Starter Problem?
So i have been reading through the threads in the search but i think each answer is pretty specific to each persons problem so here is my problem.
PROBLEM: All of a sudden (last night after i got off work) I tried to turn my car on and "CLICK" is all i here... gauge cluster lights up windows work but still my first thought is battery.... I hook my car up to be jumped turn it over again and "CLICK" same thing.... after that i wait a few and turn it over and Starts Right up and drives normal.... This morning i go to start my car again and "CLICK" i did it two more time before it started right up.?????? is this just my starter going bad or should i look elsewhere?
Thanks for all the help in advance
-Sergio
Old Sep 22, 2007 | 09:45 PM
Hondaruss's Avatar
Default Re: Starter Problem? (blaxican05)
starter is going bad.. usually if you tap on it with a hammer or hard object it will crank over. I would also check grounds as well since your start uses the motor as ground if there is not a good chassis to engine ground its hard to complete the circuit
mikej94civex
Apr 28, 2010 07:49 PM
djviet2000
Jun 9, 2008 06:40 AM
Race Egr
Jan 31, 2005 01:18 PM
85civic
Sep 12, 2004 03:24 PM
