fusebox keeps blowing - 60a
yea....this fuse blows whn i try to crank over the engine...BUT it was running good before.....ive checked all the wires to the best of my abilities, but still...nothing.,. so any input on this? or has it happend to anyone?....its the yellow 60A fuse in the fusebox the engine bay ...
The reason why fuses blow is that there it too much resistance in the circuit and causes a short. Reasons for a short. Wires are exposed of its wire, wires are burned meaning fried of too voltage on a tiny wire., or that you are putting low amperage fuse and the fuse will blow. Good luck man.
im using the fuse size that recommended,....should i use a higher amp fuse? or will that cause more problems?,such as shorting out my ecu or other wires?
