Forged internals louder than stock?
Old Sep 22, 2007 | 04:40 PM
Frozen E's Avatar
H-T White Ops
Default Forged internals louder than stock?
This may be a weird question, but do forged internals (pistons and rods, and not to mention, the block is sleeved and bored out to 84mm) make more noise idling than stock internals? This is a B16A2.
I read that somewhere a few years back but really didn't pay any attention to it since I was running a stock motor then.
Anyway, forged internals louder than stock? Yes/no?
Modified by IslandSi at 4:24 PM 9/22/2007
Old Sep 22, 2007 | 04:43 PM
doood's Avatar
been there done that
Default Re: Forged internals louder than stock? (IslandSi)
yes
forged pistons in particular will expand once up to temp and the tapping will stop or quiet down. btw, if the cylinders really are at 87mm, good luck.
Old Sep 22, 2007 | 05:22 PM
Frozen E's Avatar
H-T White Ops
Yeah, brain fart. Meant to put 84mm. Must have had 87 octane gasoline on my mind or something. :
Old Sep 22, 2007 | 05:29 PM
doood's Avatar
also, what the piston to wall clearances are set at can also determine how loud/often the tapping occurs. larger clearances mean the piston has to expand more. some pistons expand more than others based on their composition.
Old Sep 22, 2007 | 06:15 PM
HondamanXxX's Avatar
GO GIANTS!
Default Re: (IslandSi)
Good question. I also did not know that.
Old Sep 22, 2007 | 06:57 PM
2BFI's Avatar
Default Re: (HondamanXxX)
Forged pistons expand more with heat when compared to cast ones. Thus to get the required diameter at operating temps, they have to be smaller when cold.
Sold starts w/ loose pistons causes the greatest wear and tear.
Old Sep 22, 2007 | 08:11 PM
Frozen E's Avatar
H-T White Ops
I might actually get around to installing that preluber I bought YEARS ago to take care of the dry startup problem.
Old Sep 22, 2007 | 10:06 PM
NiiS's Avatar
After I built my motor I remember hearing "Piston slap." I never had this before I went with new internals. Apparently that was a good thing as far as clearances/tolerances went.
I say yes, louder in general.
92CHB
Oct 10, 2011 07:36 AM
GsrIntegra789
Jan 7, 2010 01:34 PM
h22sedan
Dec 13, 2006 03:57 PM
mz3bo
Jun 18, 2004 06:34 PM
BlueSi2k
Feb 27, 2003 11:18 PM
