need some insight on this problem
Old Sep 22, 2007 | 04:07 PM
louevilhatch's Avatar
Default need some insight on this problem
alright..i have an 89 dx hatch with a b16a. i recently thought i blew my motor to **** when the timing belt slipped...luckily nothing was wrong. in the process of checking everything out i removed the head to check the valves, pistons andwhat not and everything was good. i replaced the timing belt and the distributor cap.now i hooked everything up right, all my grounds are in(thought they were bad so i replaced when first trying to figure out problem), and the starter passed up at autozone.the car wont start and acts like it has a lack of electrical power. when i turn the ignition, i can hear the fuel pump priming and it just keeps priming. is it supposed to do that?also my dash lights are dim as well. any insight or suggestions would help...i'm running out of ideas. sorry for the short story guys, just wanted to give all the details. thanks
Old Sep 22, 2007 | 04:36 PM
DenzComp's Avatar
Default Re: need some insight on this problem (louevilhatch)
Does it turn over?
Try charging the battery.
Oh yeah..use paragraphs too.
Old Sep 22, 2007 | 04:38 PM
Default Re: need some insight on this problem (DenzComp)
nope,it doesn't turn over. i already charged the battery.
Old Sep 22, 2007 | 04:45 PM
DenzComp's Avatar
Common rule of thumb when something quits working....
Go back and check the last thing you did that would effect it...that's probably the problem...
Whatever electrical you messed with is where the problem is...
lattimer2012
May 15, 2011 12:19 PM
sleepyitr
May 1, 2008 04:22 PM
pliskin679
13
Aug 3, 2007 09:30 PM
1990CIVIC4WD
Sep 26, 2003 07:17 AM
