steering wheel shaking at high speed
my steering wheel starts to shake when i get above 50mph. what is causing this? tires are balanced. rims are new. centric rings are on front 2 wheels. any ideas?
Have you tried taking the wheels off and putting them back on with a torque wrench...a lot of times you can take wheels off and on and get different sounds/vibrations each time if you don't torque everything just right.
well who balanced them? someone careless could've halfassed balanced them...not as accurately. also it could be the tire is out of round. tires arent always manufactured perfectly.
what does your alignment look like? if yours is out, that could also cause a shake
it was balanced by this tire shop i go to. if i had a bad cv joint will it make some kind of sound when i turn the steering wheel to a certain side? because when i turn my wheel to the right it makes this sound.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeJdm »</TD></TR><TR><TD CLASS="quote">it was balanced by this tire shop i go to. if i had a bad cv joint will it make some kind of sound when i turn the steering wheel to a certain side? because when i turn my wheel to the right it makes this sound. </TD></TR></TABLE>
it will usually make a sound. however, if the inner cv joint goes, it may not make a clicking sound or an irregular noise, and just cause vibration.
i have the same problem, only its on a 04 S2000, drive about 60-and up it starts shaking, put some diff wheels on it and the problem is still there, must be the axles or something else.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluedlude »</TD></TR><TR><TD CLASS="quote">FYI, i know i have had a ripped, nearly empty CV boot for quite a while now. it makes no noise. not even when i turn. but it does shake at high speed. look at your axles.</TD></TR></TABLE>
yea, my axles are the cause of my wheel hop on the street
good thing i dont track with street tires
took it to the shop and it was a bad tie-rod..they went to get it aligned but they couldnt cuz the car is lowered and that i have bad camber wear...what can i do to fix this?
hondaguyexsi
Aug 19, 2005 02:35 PM
Nizzy
Aug 21, 2003 07:31 AM
