89crx si b16swap no power
Old Sep 22, 2007 | 10:34 AM
crxkidd84's Avatar
Default 89crx si b16swap no power
I did a b16 obdo swap with all necessary conversion parts from hasport, motor starts and idles fine, no smoke. BUt seems to not have the power that should be there like something is holding it back. Any help i would appreciate it!!!!
Old Sep 22, 2007 | 01:43 PM
Aristotle's Avatar
Check timing.
Old Sep 22, 2007 | 05:03 PM
Donkey85's Avatar
Default Re: (Aristotle)
did you give the new motor a tune as well? ie. plugs, wires, cap, rotor, pcv valve, o2 sensors. if you didnt i would start with that stuff
Old Sep 23, 2007 | 06:02 AM
dr.carvorkian's Avatar
Default Re: (Donkey85)
ignition timing perhaps, cam timing more likely.
Old Sep 23, 2007 | 06:06 AM
The_Undertaker's Avatar
75.168.105.221
Do you have vtec wired up? Are you really beating on it to activate vtec. Vtec on stock pr3 or pw0 ecu is 5500 rpm. HIgh end power becasue small displacement engine and requires high revving for vtec. I will start here then tune it.
Old Sep 25, 2007 | 06:49 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
Default Re: (1988hondacrxsiR1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1988hondacrxsiR1 &raquo;</TD></TR><TR><TD CLASS="quote">Do you have vtec wired up? Are you really beating on it to activate vtec. Vtec on stock pr3 or pw0 ecu is 5500 rpm. HIgh end power becasue small displacement engine and requires high revving for vtec. I will start here then tune it.</TD></TR></TABLE>
WHAT THE expletive ARE YOU TALKING ABOUT????? You really need to stop making worthless posts. You obvious have no mechanical aptitude whatsoever and you keep trying to make us think other wise. STOP IT. JUST ******* STOP IT.
touintegra1
Aug 13, 2023 08:28 PM
graevz
Jul 26, 2017 04:13 PM
Inextricabledrvr
May 1, 2007 03:36 AM
aquarius
Jul 11, 2004 04:44 AM
garados
Jan 24, 2002 05:44 PM
