will ZC (DOCH) OR D16(DOCH) fit on my car
I've a 96 civic with D15z4 .Will ZC and D16 will fit in my car without changing anything?
Modified by 96_bhr at 7:16 AM 9/22/2007
well first of all its dohc not doch and second seach but for quick awnser yes u have a d-series in ur car and the zc and d16 are d-series so they fit. and also the only d16 that was dohc is the ZC so ur talkin about the same motor right?
sorry my mistake .
as i know nothing will be change only the upper radiator hose . so my Q about mounting ,power steering....etc.
what is the difference between ZC and D16..
thanx
thanx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slowass2dr »</TD></TR><TR><TD CLASS="quote">well first of all its dohc not doch and second seach but for quick awnser yes u have a d-series in ur car and the zc and d16 are d-series so they fit. and also the only d16 that was dohc is the ZC so ur talkin about the same motor right?</TD></TR></TABLE>
I dunno if your stating that the D16A1 was a ZC.. last i knew the ZC was stampped ZC.. and the D16A1 was stamped D16A1.. so its not the only one...
old school integra dohc
http://hondaswap.com/attachmen...8.jpg
http://hondaswap.com/attachmen...9.jpg
there are two pictures of a d16a1 ...
well i know for a fact that the JDM zc fits with no mods, maybe some wireing....i think iv heard somewere that the US model ZC dont fit because of mounts??? not sure though....BTW u can use ur stock trans just place ur flywheel onto the motor ur using
I'm gonna swap my trans with 5spd S20 or S40 ..
I'm confused coz my friend owns a Del sol with ZC with S20 and his ratios is very good for daily use .But S40 is shorter gear ratios .
IS S20 LSD?
IS S20 LSD?
that would be stupid to swap that motor in your car u have an obd2 motor u cant got to obdo without some major downgrading!!!!! and plus it wouldnt pass inspection this is not going to work properly if u want a d sderies motor swap do a d16y8 that is the d obd2 motor that will work properly
waste of time man..........those motors arent great.........first gen integra (av1) motors
d16a1
dohc zc are the same motor, all they're good for are the pistons, bt you cant resurface the block or head on a standard d16z/y motor to get the clearances right so then again its a wash plus an all motor 1-6 is not waht you want anyway
d16a1
90wagon4wd
Jan 9, 2004 06:01 AM
Westrock2000
May 8, 2003 08:00 AM
