I have a quick question about my SRI
Old Sep 21, 2007 | 08:23 PM
ogliquidmetal's Avatar
Default I have a quick question about my SRI
Hey, I'm kinda new to this, so here it goes. When I was installing it, my SRI came with a long thin hose, and I didn't recognize it because my CAI had a short hose that's about 2.5 inches. So my question is, am I supposed to cut this hose and make it look like this:
or am I supposed to completely disconnect the metal tube thingy and have it run straight into the engine like this:
Thanks in advance
Old Sep 21, 2007 | 08:28 PM
JDM_Acccord's Avatar
Default Re: I have a quick question about my SRI (ogliquidmetal)
either way it's going into the engine, with or without that metal adapter piece. so it would not matter.
Old Sep 21, 2007 | 08:32 PM
Default Re: I have a quick question about my SRI (JDM_Acccord)
Thanks for the super quick reply JDM :D
So the metal one doesn't obstruct the airflow or anything since it seems like its smaller ?
Also, what if I were to only get a muffler tip and keep my old piping. Would it alter the noise of my car ? Would it be any louder ?
Old Sep 21, 2007 | 08:37 PM
no, it will not mess with your air flow.
and a tip will most likely not make your car louder.. just save up and buy a full exhaust.
Old Sep 21, 2007 | 08:39 PM
gianinline's Avatar
Well... the pictures show 2 different applications.. d series and a f series.
Either way, the metal piece, i simply cut it off, and bypassed the rubber straight from the intake to the engine, as seen on the picture with a red engine bay (d series). I also, bypassed the water hose that went through the same metal piece, so at the end, i actually deleted that metal piece, without loosing a thing, and all functional still!
Gotcha JDM
Wait wait wait. What water pipe ? Do I have to mess with that when installing my SRI ?
Thanks for the help! My buddy told me you guys would tare me apart here on these forums, but I guess its pretty friendly ehhh
OH YA!
What are those two metal pieces ? Lol. They look like they're supposed to be some kinda brace, but I can't figure out how to put them on the SRI then attach them to my car.
Modified by ogliquidmetal at 10:00 PM 9/21/2007
Old Sep 21, 2007 | 08:54 PM
that metal connector piece contains two seperate connections... the top one is where the intake is and the bottom one carries coolant i believe. you can bypass that whole metal piece as stated above by connecting that hose from the intake to the engine.
and i think those metal pieces are some type of bracket.. some of those weird brand intakes don't always fit the way you'll like.
Old Sep 21, 2007 | 09:02 PM
Heh, I couldn't find a place to put those brackets, so I just left them out. I can shake my intake around with my hand, but as long as it doesn't fall off right ? Lol.
So I guess I'll put in the longer rubber thing tomorrow. As long as I don't touch the bottom one (the one with the coolant) I should be fine right ?
Old Sep 21, 2007 | 09:15 PM
correct.. i wouldnt mess with the bottom one.. a while back i did, and accidently made a small splice in the hose which caused coolant to leak and my car to overheat which then ruined my day over something so small.
m4bandit
Honda Civic (2001 - 2005)
Jun 7, 2008 11:21 PM
flatblack-h22
Jul 16, 2007 08:01 AM
vinuneuro
Jul 15, 2006 07:23 PM
terminaloverlowd
Jun 16, 2004 11:09 PM
